Non Conformal Coupling interface in Centrifugal Pump - OpenFOAM v11 |
October 19, 2023, 04:28 |
Pedro Gouveia
Rep Power: 3 |
Hello everyone,
I am an Aeronautical Engineering student working in his Master Thesis about Numerical Analysis of a Centrifugal Pump. The initial analysis is a steady state. I am using the MRF approach, with 3 domains separate, as you can see from the attached picture. The inlet is in the y direction the dark blue surface from the purple domain and the outlet is radial, represented by the light blue surface from the pink domain. Thus, and since I am using OF v11, I need to make use of the NCC tool they provide. If you go to the documentationpage, you will see that, for surfaces that fully overlap, you should use movingWallSlipVelocity (or slip if the mesh is stationary) for velocity U; zeroGradient or fixedFluxPressure for pressure p; zeroGradient for other fields. The mesh has around 720000 elements, the pump has around 30 cm diameter, with 600 rpm. The working fluid is water. I am performing a laminar analysis, and using the following boundary conditions: Velocity: Code:
inlet { type pressureInletOutletVelocity; value $internalField; } outlet { type flowRateInletVelocity; volumetricFlowRate 0.01356; profile laminarBL; } "(wall_1|wall_2|bladeWalls|wall_3)" { type noSlip; } "(NCC1_2|NCC2_1)" { type slip; } "(NCC2_3|NCC3_2)" { type noSlip; } Code:
inlet { type fixedValue; value uniform 0; } outlet { type zeroGradient; } "(wall_1|wall_2|bladeWalls|wall_3)" { type zeroGradient; } "(NCC1_2|NCC2_1)" { type zeroGradient; } "(NCC2_3|NCC3_2)" { type zeroGradient; } I can't understand why there are "aureolas" where the non conformal coupling interfaces are. The tutorials are only showing moving components, but I want to simulate a static component. Does anyone have any idea of what I could be doing wrong? Thank you in advance. |
January 15, 2024, 09:30 |
Re
Vlad
Rep Power: 2 |
Can you share your case? I'm student and really don't understand how NCC is working and some waves to move case from ACMI method to NCC
January 16, 2024, 05:39 |
Pedro Gouveia
Rep Power: 3 |
Hey,
I am now using another centrifugal pump that I found in a paper. What do you mean when you say you don't understand how NCC is working an some waves? |
January 16, 2024, 07:19 |
#4 | |
Vlad
Rep Power: 2 |
I'm used OF v2306 to research aerodynamic characteristics of rotating projectile with feather stabilizers with using ACMI method. Now I need to do the same thing using the NCC method. There was a difficulty in translating the case from the AMCI method from v2306 to the NCC method from v11. Unfortunately, so far, as I understand it, the Internet is not yet rich in examples of using a rotating mesh using the NCC method. An additional difficulty lies in the syntax discrepancy between the branches of OF, which makes it difficult to switch from one version to another due to the imposition of errors due to the lack of ACMI support and the lack of perception of directories due to the syntax. Sorry for the obvious questions, I'm a novice user OF |
January 16, 2024, 09:04 |
#5 | |
Pedro Gouveia
Rep Power: 3 |
Dear prud1k, I am also facing the same issue. There is really not enough data regarding the new feature "Non-conformal coupling" present in OF11 (and OF10 I believe). I am attaching here my case directory. However, I would not use it as a faithful example, since I am facing some issues myself. For instance. I am using four different regions, thus having six non conformal patches (NCC1_2, NCC2_1, NCC2_3, NCC3_2, NCC4_3, NCC3_4). Four of those six regions are in contact with the MRF zone. One issue I am having is, should I declare them as nonRotatingPatches() in the /constant/MRFProperties file or not? Anyways, if anyone could help us regarding this issue it would be awesome. I am leaving here the files you need and the methodology I am using. I will keep this thread updated with the results I am getting. I am testing with kEpsilon at the moment, although I was using SST for some weeks. Please comment if you have any doubts Methodology: 1 - having a separate directory for each region you are using. Each directory should have a constant, system and 0 folder (I am not sure if the 0 folder is necessary). 2 - Meshing each component in the respective directory. I am currently using salome for meshing, since I believe tetraheadron are better for centrifugal pump than cartesian hexa. 3 - After meshing all components, you should use "mergeMesh" command to merge all meshes into one directory. Usage is "> mergeMesh /Domain_2 /Domain_1 - overwrite". Keep doing it untill all domain is in one folder. 4 - Perform a "checkMesh" command inside the folder with all the regions. It will state that there are "x" separate regions, and will write all of them in a "set" folder. 5 - If you are doing steady state, now you must select the MRFzone. I use "topoSet" for it. If you did step nr 4, you will have the MRF region already present in a /set folder. If you compare the nr of elements of each region (given in checkMesh) you will know which one is the impeller/fan. 6 - "createNonConformalCouples" command. Since I have more than one NCC, I have a file defining them, called "createNonConformalCouplesDict", so I just have to run createNonConformalCouples in the terminal. 7 - run. ---------------------------------- NonConformalCouplesDict Code:
// Whether or not to add boundary conditions for the added patch to the fields fields no; // The list of non-conformal couples to be created. Each entry in this section // creates a single non-conformal coupling. nonConformalCouples { nonConformalCouple_12 { patches (NCC1_2 NCC2_1); transform none; } nonConformalCouple_23 { patches (NCC2_3 NCC3_2); transform none; } nonConformalCouple_34 { patches (NCC3_4 NCC4_3); transform none; } } Code:
actions ( /* { name MRFSet; type cellSet; action new; source cylinderAnnulusToCell; p1 (0 -0.01 0); p2 (0 0.02301 0); outerRadius 0.14301; innerRadius 0.05701; } */ { name MRFZone; type cellZoneSet; action new; source setToCellZone; sourceInfo { set region2; } } ); Code:
boundaryField { #includeEtc "caseDicts/setConstraintTypes" "NCC.*" { type zeroGradient; } outlet { type pressure; p $internalField; value $internalField; } "wall.*" { type zeroGradient; } "blade.*" { type zeroGradient; } inlet { type zeroGradient; } } Code:
boundaryField { #includeEtc "caseDicts/setConstraintTypes" "NCC.*" { type slip; } outlet { type pressureInletOutletVelocity; value $internalField; } "wall.*" { type noSlip; } "blade.*" { type MRFnoSlip; value uniform (0 0 0); } inlet { type flowRateInletVelocity; volumetricFlowRate { type constant; value 0.0063; } value uniform (0 0 0); } } Code:
boundaryField { #includeEtc "caseDicts/setConstraintTypes" "NCC.*" { type zeroGradient; } outlet { type calculated; value uniform 0; } "wall.*" { type nutkWallFunction; value uniform 0; } "blade.*" { type nutkWallFunction; value uniform 0; } inlet { type calculated; value uniform 0; } } Code:
boundaryField { #includeEtc "caseDicts/setConstraintTypes" "NCC.*" { type zeroGradient; } outlet { type inletOutlet; inletValue $internalField; value $internalField; } "wall.*" { type kqRWallFunction; value uniform 1e-12; } "blade.*" { type kqRWallFunction; value uniform 1e-12; } inlet { type turbulentIntensityKineticEnergyInlet; intensity 0.05; value uniform 1; } } Code:
boundaryField { #includeEtc "caseDicts/setConstraintTypes" "NCC.*" { type zeroGradient; } outlet { type inletOutlet; inletValue $internalField; value $internalField; } "wall.*" { type epsilonWallFunction; value $internalField; } "blade.*" { type epsilonWallFunction; value $internalField; } inlet { type fixedValue; value $internalField; } } Code:
MRFImpeller { cellZone MRFZone; active yes; nonRotatingPatches (NCC1_2|NCC2_1|NCC2_3|NCC3_2); origin (0 0 0); axis (0 0 1); omega constant 64.9262481; } |
January 16, 2024, 10:50 |
Vlad
Rep Power: 2 |
Dear unilord,
Thanks a lot. In addition to my question: Have you come across a GPU connection for calculations? On this forum, I read that the connection takes place using third-party libraries with PETSc and AMGXWrapper, do you know what other methods exist? |
January 16, 2024, 14:55 |
#7 | |
Pedro Gouveia
Rep Power: 3 |
Hey prud1k, As far as I know, there is no opensource/free tool that allows the usage of GPU in openfoam. There is one thing that I am aware about, which is called dicehub, but they do not provide GPU for openfoam (not 100% sure). The guys there gave me some hours in exchange of using my simulation to put in their website. However they only gave me in CPU hours. There is a freelancer engineer called Giles Richardson in LinkedIn that is always posting simulations made in UFOCFD (it's another code) ran in a GPU |
January 16, 2024, 15:02 |
Pedro Gouveia
Rep Power: 3 |
I am also going to leave here the results of my analysis, in case that someone with more experience than me wants to provide feedback.
I am using kEpsilon at the moment. yPlus between 30 and 200. I am using upwind for divSchemes of k and epsilon (diffusive terms), and linearUpwind for convective terms. However, I want to use linearUpwind for diffusive terms as well. However, when I try to do so, my simulation gives me "bounding omega" value of around E+16, which is obviously wrong. The mesh is tetrahedral, with hexahedral as boundary layer and some polyhedral. fvSolution Code:
solvers { p { solver GAMG; tolerance 1e-08; relTol 0.0; smoother GaussSeidel; agglomerator faceAreaPair; nCellsInCoarsestLevel 1000; } U { solver smoothSolver; smoother GaussSeidel; tolerance 1e-08; relTol 0.0; } k { solver smoothSolver; smoother GaussSeidel; tolerance 1e-08; relTol 0.0; } epsilon { solver smoothSolver; smoother GaussSeidel; tolerance 1e-08; relTol 0.0; } Phi { solver GAMG; smoother DIC; tolerance 1e-06; relTol 0.01; } yPsi { solver GAMG; smoother GaussSeidel; cacheAgglomeration true; nCellsInCoarsestLevel 100; agglomerator faceAreaPair; mergeLevels 1; tolerance 1e-6; relTol 0; } } potentialFlow { nNonOrthogonalCorrectors 3; } SIMPLE { momentumPredictor yes; nNonOrthogonalCorrectors 2; nCorrector 0; residualControl { p 1e-6; U 1e-7; k 1e-7; epsilon 1e-7; } } relaxationFactors { fields { p 0.3; } equations { U 0.7; k 0.7; epsilon 0.7; } } fvSchemes Code:
ddtSchemes { default steadyState; } gradSchemes { default Gauss linear; grad(U) cellMDLimited Gauss linear 0.333; } divSchemes { default none; div(phi,k) Gauss upwind k; div(phi,epsilon) Gauss upwind epsilon; div(phi,U) bounded Gauss linearUpwind grad(U); div((nuEff)*dev2(T(grad(U)))) Gauss linear; } laplacianSchemes { default Gauss linear limited corrected 0.5; } interpolationSchemes { default linear; } snGradSchemes { default limited corrected 0.5; } wallDist { method Poisson; } Code:
Checking geometry... Overall domain bounding box (-0.160034 -0.194078 -0.0123) (0.235363 0.409899 0.2409) Mesh has 3 geometric (non-empty/wedge) directions (1 1 1) Mesh has 3 solution (non-empty) directions (1 1 1) Boundary openness (1.79101e-16 -1.00849e-16 -8.91094e-16) OK. Max cell openness = 5.34516e-16 OK. Max aspect ratio = 12.9508 OK. Minimum face area = 3.30405e-08. Maximum face area = 1.60733e-05. Face area magnitudes OK. Min volume = 5.95973e-12. Max volume = 3.00018e-08. Total volume = 0.00436354. Cell volumes OK. Mesh non-orthogonality Max: 69.9681 average: 16.6896 Non-orthogonality check OK. Face pyramids OK. Max skewness = 2.23813 OK. Coupled point location match (average 0) OK. Mesh OK. End |
centrifugal pump, non conformal interface, openfoam 11 |
OpenFOAM course for beginners | Jibran | OpenFOAM Announcements from Other Sources | 2 | November 4, 2019 08:51 |
Interface setting in cfx centrifugal pump | Ahmed Saeed Mansour | CFX | 0 | September 23, 2016 20:27 |
Error - Solar absorber - Solar Thermal Radiation | MichaelK | CFX | 12 | September 1, 2016 05:15 |
centrifugal pump | Chalghoum | CFX | 18 | April 16, 2014 06:37 |
Replace periodic by inlet-outlet pair | lego | CFX | 3 | November 5, 2002 20:09 |
