OpenFOAM heatflux and convection
Old   February 3, 2024, 00:09
Default OpenFOAM heatflux and convection
Ibrahim I
Ibrahim_I is on a distinguished road
Hi, in my 0/T folder on one wall I need a heat flux (W/m^2) and convective heat flux (W/m^2K). I tried defining these conditions separately for the same wall or putting it in the same bracket but openfoam only uses one of them not both. Is there a way of doing this without using swak4foam? Example code below in which openfoam only uses the second condition.
top_wall
type externalWallHeatFluxTemperature;
value $internalField;
q uniform 1000.0;
mode flux;
kappaMethod solidThermo;
qr none;
kappa none;
thicknessLayers ();
kappaLayers ();
top_wall
mode coefficient;
Ta constant 313.0;
h uniform 17.0;
Ibrahim_I is offline   Reply With Quote
Visualizing Heat Transport for forced Convection in Fluids max.e Visualization & Post-Processing 0 December 10, 2021 06:30
Solid-Solid Heatflux of Moving Roller Torque_Converter CFX 4 May 22, 2012 19:22
air flow simulation in double skin facade with openfoam gygfei OpenFOAM 1 December 20, 2010 04:50
