foam fatal error cannot dereference nullptr at index 1 in range [0,1)
Old   February 15, 2024, 00:04
Default foam fatal error cannot dereference nullptr at index 1 in range [0,1)
Ibrahim
Ibrahim1 is on a distinguished road
I was ruuning a case with 2 fluid region, and 2 solid region
Now I have removed one fluid region so my regionproperties file of constant folder changed from
regions
fluid (gas1 gas2)
solid (Solid1 Solid2)
to
regions
fluid (gas1)
As I run with these condition I gets an error "foam fatal error cannot dereference nullptr at index 1 in range [0,1)"
this is happening as i have removed the gas2 region from region properties of fluid
regions
fluid (gas1)
If i change this to
regions
fluid (gas1 gas1)
its working fine, but it solves gas region twice which is not correct,
Anyone know how to solve such issue
Thanks!
Ibrahim1 is offline   Reply With Quote
openfoam2.1.x
[Commercial meshers] Problem with Mesh conversion from FLUENT Meshing to OpenFOAM mn17jyf OpenFOAM Meshing & Mesh Conversion 3 November 1, 2023 09:49
whats the cause of error? immortality OpenFOAM Running, Solving & CFD 13 March 24, 2021 07:15
[mesh manipulation] refineMesh Error mohsen.boojari OpenFOAM Meshing & Mesh Conversion 3 March 1, 2018 22:07
Index out of range fatal error Rahand OpenFOAM Programming & Development 1 April 13, 2016 13:35
is internalField(U) equivalent to zeroGradient? immortality OpenFOAM Running, Solving & CFD 7 March 29, 2013 01:27
