How can I use MapFields for this geometry?
Old   March 25, 2024, 17:00
Default How can I use MapFields for this geometry?
Mahdi
Mahdi_Kh is on a distinguished road
Dear all,
I am using mapFields for the first time to map the flow field from a coarser mesh to a finer one. The geometry is attached here. The boundary names and boundary conditions are the same between two meshes and the geometry of course. When I am using the syntaxes, I have found so far, it gives me several errors, for example, it creates 'nan' values and then exit for such error.
Can anyone guid me through this please? I have cyclicAMI at inlet and outlet, and other boundary names and conditions are shown in the figure.
I am using this as mapfieldsdict. Shoud I use any field for patchMapMethod for example since I have cyclicAMI? or what should I use for patchMap?
Thank you so much,
Mahdi.
FoamFile
version 2.0;
format ascii;
class dictionary;
object mapFieldsDict;
mapFields1
// Mandatory entries (unmodifiable)
type mapFields;
libs (fieldFunctionObjects);
// Mandatory (inherited) entries (runtime modifiable)
// fields (<field1> <field2> ... <fieldN>);
mapRegion region0;
mapMethod cellVolumeWeight;
consistent true;
// Optional entries (runtime modifiable)
// patchMapMethod direct; // AMI-related entry
// enabled if consistent=false
// patchMap (<patchSrc> <patchTgt>);
// cuttingPatches (<patchTgt1> <patchTgt2> ... <patchTgtN>);
patchMap ()
cuttingPatches ()
// Optional (inherited) entries
region region0;
enabled true;
log true;
timeStart latestTime;
timeEnd 1000;
executeControl timeStep;
executeInterval 1;
writeControl timeStep;
writeInterval 1;
Thank you so much,
Mahdi.
Mahdi_Kh is offline   Reply With Quote
One or more objects may have lost some scoping attachments during the geometry update jaxk CFX 1 October 10, 2023 17:51
How do I connect a geometry to my solver devansh.purohit Main CFD Forum 4 November 16, 2021 08:51
Running CFD parallel. There is no geometry file! CrashLaker SU2 6 April 10, 2014 03:08
[CAD formats] translating geometry from Abaqus to OpenFOAM skuznet OpenFOAM Meshing & Mesh Conversion 3 January 10, 2014 13:49
Problem Importing Geometry ProE to CFX fatb0y CFX 3 January 14, 2012 19:42
