April 24, 2024, 09:29 |
OpenFOAM DTCHull Tutorial alpha.water Error
Hi, I am trying to use the DTCHull tutorial to model water and air flow around a kayak. I am getting a floating point error every time I run interFoam, which I think has something to do with the alpha.water file. I used setFields to define which regions will be filled with water, and I set all of the regions to be filled with air initially in alpha.water. I was able to go through the same process and run the dambreak tutorial, but for some reason whenever I run the DTCHull tutorial I get a floating point error, unless I set the internal field equal to 1 in the alpha.water file and make everything filled with water.
I've also looked at the DTCHull tutorials that have been posted on github, and I've also noticed that they have bottom, side, and midplane boundaries in blockmesh, but not in any other files. When I try to delete those boundaries in other files I am not able to run the simulation. I am very new to OpenFOAM and would appreciate any help! |
Compile calcMassFlowC | aurore | OpenFOAM Programming & Development | 13 | March 23, 2018 07:43 |
OpenFOAM v3.0+ ?? | SBusch | OpenFOAM | 22 | December 26, 2016 14:24 |
Compiling dynamicTopoFvMesh for OpenFOAM 2.1.x | Saxwax | OpenFOAM Installation | 25 | November 29, 2013 05:34 |
Problem with compile the setParabolicInlet | ivanyao | OpenFOAM Running, Solving & CFD | 6 | September 5, 2008 20:50 |
How to get the max value of the whole field | waynezw0618 | OpenFOAM Running, Solving & CFD | 4 | June 17, 2008 05:07 |
