May 16, 2024, 02:10 |
Ubuntu Allrun command
Rep Power: 2 |
Hi everyone, i have problem running command below. Why is it appears command not found?
shukrie@DESKTOP-GM7974Q:~/Run/FirstTime/motorBike$ -processor -processor: command not found Below is the Allrun file for this simulation #!/bin/sh cd "${0%/*}" || exit # Run from this directory . ${WM_PROJECT_DIR:?}/bin/tools/RunFunctions # Tutorial run functions #------------------------------------------------------------------------------ # copy motorbike surface from resources directory mkdir -p constant/triSurface cp -f \ "$FOAM_TUTORIALS"/resources/geometry/motorBike.obj.gz \ constant/triSurface/ # Make dummy 0 directory mkdir -p 0 runApplication blockMesh runApplication decomposePar -decomposeParDict system/decomposeParDict.hierarchical runParallel snappyHexMesh -decomposeParDict system/decomposeParDict.ptscotch -profiling -overwrite find . -iname '*level*' -type f -delete #- Set the initial fields restore0Dir -processor runParallel renumberMesh -overwrite runParallel potentialFoam -initialiseUBCs -writephi runParallel checkMesh -writeFields '(nonOrthoAngle)' -constant runParallel $(getApplication) #------------------------------------------------------------------------------ |
May 16, 2024, 03:06 |
Yann
Rep Power: 26 |
shukrie@DESKTOP-GM7974Q:~/Run/FirstTime/motorBike$ -processor If you want to run the Allrun script, you should type something like this: Code:
./Allrun Yann |
May 17, 2024, 02:35 |
Rep Power: 2 |
i want to run the restore0Dir, in the Allrun file it said that the command is
-processor however, when i trigger the command, it said that the command is not found. |
May 17, 2024, 03:28 |
Yann
Rep Power: 26 |
-processor is not a command, the command is actually Code:
restore0Dir -processor in the Allrun script, run functions are loaded by this line at the beginning of the script: Code:
. ${WM_PROJECT_DIR:?}/bin/tools/RunFunctions # Tutorial run functions More about run functions: https://damogranlabs.com/2020/10/run...ck-cheatsheet/ Cheers, Yann |
May 17, 2024, 04:38 |
Rep Power: 2 |
Thanks a lot for the assistant. I am new to CFD openFoam. This helps really much. Thanks Shukrie |
[OpenFOAM.com] Paraview command error. OpenFOAM 8, Ubuntu 20.04 | sungmin130 | OpenFOAM Installation | 0 | October 20, 2020 12:26 |
[foam-extend.org] Ubuntu 14.04, Foam-extend 3.1: "command not found" | KangX1 | OpenFOAM Installation | 31 | September 27, 2016 16:30 |
Problems after 'make install' command in Ubuntu | Sparsh | SU2 Installation | 2 | October 30, 2015 14:37 |
OpenFOAM 1.7.1 installation problem on OpenSUSE 11.3 | flakid | OpenFOAM Installation | 16 | December 28, 2010 08:48 |
Please help me | liugx212 | OpenFOAM Running, Solving & CFD | 4 | November 15, 2005 16:14 |
