May 17, 2024, 19:37 |
Error while reading results
Pedro Gouveia
Rep Power: 3 |
Hello guys,
I am running some centrifugal pump analysis. I run it on a 24 physical core intel 9-13xxxx CPU. I am facing some problems while post-processing the results. When I try to reconstruct the simulation, sometimes (randomly) i get these errors: error nr 1 Code:
--> FOAM FATAL IO ERROR: wrong token type - expected Scalar, found on line 122860 the word 'p00136100078' file: /home/vonkarman/PG/kEpsilon_analysis/outlet_cubeBackground_Ref1/processor21/400/nut at line 122860. From function Foam::Istream& Foam::operator>>(Foam::Istream&, Foam::doubleScalar&) in file lnInclude/Scalar.C at line 101. FOAM exiting error nr 2 Code:
Reconstructing point fields No point fields No lagrangian fields double free or corruption (out) Aborted (core dumped) Regarding the error nr 1, when I go to the line that is mentioned, letters appear in the middle of the results. Strange glyphs also appear. This happens not only on that line, but on several after that one. Does someone have any idea of what might be happening? |
May 20, 2024, 04:24 |
Pedro Gouveia
Rep Power: 3 |
Hey guys, anyone might have any idea? This is really impacting my thesis deadline so I would be really grateful if anyone could help. I already wondered if it might be due to the ubuntu or openfoam instalation, but i am not sure.
OpenFOAM floating point Error | upuli | OpenFOAM Programming & Development | 5 | June 20, 2016 03:19 |
Problem in running ICEM grid in Openfoam | Tarak | OpenFOAM | 6 | September 9, 2011 17:51 |
A basic doubt on reading the iteration results | hariya03 | OpenFOAM Post-Processing | 0 | July 16, 2008 08:28 |
[Commercial meshers] FluentMesh conversion problem | waynezw0618 | OpenFOAM Meshing & Mesh Conversion | 12 | November 30, 2006 23:12 |
Help: reading results in fortran | Quarkz | Main CFD Forum | 7 | July 21, 2005 14:17 |
