Please estimate time required to accomplish a project
Old   February 5, 2008, 11:46
Default Hello, can you estimate how
kar
Kārlis Repsons
kar is on a distinguished road
can you estimate how much time it would take to create a solution for following problem:
By putting AC on induction coil, a metal in crucible inside it is melted. Induction coil, crucible and molten metal geometries are known (axisymmetric).
It is necessary to calculate only average magnetic induction and electric field from where static magnetic forces and heat sources can be expressed.
Since metal density ro = ro(T) and flow is turbulent, buoyantFoam should be modified to include heat sources and magnetic field forces.
As for the magnetic and electric field, situation seams to be worse - that requires to write solver from scratch (correct me if I'm wrong).
Of course, all the meshing is neccessary to do.
After doing transient calculation, results must be averaged.
Assuming, that all the necessary theory is known, how much time this would require for somebody well trained in OpenFOAM?
Thank you!
kar is offline   Reply With Quote
estimate time step? CFD Student Main CFD Forum 7 August 12, 2005 01:16
how to estimate the total cosuming time? gjy0775 CFX 4 July 6, 2004 12:06
Unstructured Viscous Time Step Estimate Anthony Iannetti Main CFD Forum 8 July 15, 2001 11:24
How to estimate numerical diffusion ? Mukhopadhyay Main CFD Forum 3 June 19, 2001 09:35
Information required on Fluid bed project M Choudhury Main CFD Forum 0 October 8, 1998 05:52
