What is the c3 coefficient in k-epsilon model?
Like Tree7Likes
  • 1 Post By sega
  • 1 Post By sega
  • 2 Post By RJ87
  • 1 Post By galap
  • 1 Post By fumiya
  • 1 Post By wyldckat
Old   June 5, 2009, 08:24
Default What is the c3 coefficient in k-epsilon model?
Marcin Hinz
Marcin is on a distinguished road
Hi everyone!
I've tried to find some informations about the coefficients in the k-epsilon turbulence model and i found the c3, a coefficient which I can't find enywhere else. Does anybody know know what is it? And how big should be the value of it? I think the default value is -0.33. Why negative?
Thank's for any help.
Best regards,
Marcin
Marcin is offline   Reply With Quote
Old   June 7, 2009, 16:58
sega's Avatar
Sebastian Gatzka
sega is on a distinguished road
As "mentioned" in the code the default value for c3 is -0.33 and is corresponding to compressible flow only.
It is included in the dissipation equation for epsilon.
atulkjoy likes this.
Schrödingers wife: "What did you do to the cat? It's half dead!"
sega is offline   Reply With Quote
Old   June 9, 2009, 02:12
Marcin Hinz
Hallo Sebastian,
thank you for your reply. I have also found these informations in the code. The problem is, I don't uznderstand them. I have comared some equations implemented in OpenFOAM with other, commercial codes (for example CFX) and most of them are simmilar or the same exept for the dissipation equation. I have also compared this equation with some literature and I haven't found anywhere else the C3 coefficient exept for some papers, where the C3 was 0.85. I have also searched for -0.33 value but without success. I would be pleased for some help.
Best regards,
Marcin
Old   June 9, 2009, 05:59
sega's Avatar
Sebastian Gatzka
You habe obviously done far more research on this topic than me.
I'm quite new to turbulence and have only dealt with incompressible fluids so far.
Tough enough without compressible fluids
Old   June 10, 2009, 02:11
Marcin Hinz
Hallo Sebastian,
thak you anyway for your help. All my simulations are compressible and turbulent. The problem is, i have done some simulations of a stator blade of a compressor and comared the results of OpenFOAM with CFX. All values like velocities, pressure, mach number, kinetic energy and temperature of both simulations are quite similar with small or very small differences. The only problematic value is the dissipation. The difference between these codes is quite big with a value between 1e4 and 1e6 in depand of the position. I have no idea what could be the cause. When i change the C3 coefficient from -0.33 to 0.85 it doesn't seem to make a difference in the simulation, but I would anyway like to know, what it is.
Regards,
Marcin
Old   June 11, 2009, 01:48
wayne.zhang
waynezw0618 is on a distinguished road
Send a message via MSN to waynezw0618 Send a message via Skype™ to waynezw0618
Hi Marcin
How do you give the inlet boundary value of k and epsilon for you blade?
i am doing the simulation with water pump.it is easy to give a value for SST ,but for k-epsilon,i always get divgence. i tried two ways
1 calculating it from the according the Programme guide P84
2 post the CFX result to get the k and epsilon value
but both leaded to divgence within 100 steps
how can I do
wayne
Originally Posted by Marcin View Post
Hallo Sebastian,
Regards,
Marcin
waynezw0618 is offline   Reply With Quote
Old   June 15, 2009, 02:31
Marcin Hinz
Dear Wayne,
I had also problems with the inlet boudary conditions for k and epsilon. I have also tried to set up predetermined values, but it doesn't seem to work in both codes. The one way you can loose it is:
the boudary condition for k:
type turbulentIntensityKineticEnergyInlet;
intensity 0.05;
value $internalField;
and for epsilon:
type turbulentMixingLengthDissipationRateInlet;
mixingLength 0.005;
This is also the default adjustment in CFX in inlet. The problem is, that I get with these settings different results for k and epsilon in OpenFOAM and CFX and I don't know where these diffrences come from.
I would be pleased, if you could inform me about your results and how you solve your problem.
Regards, Marcin
Old   June 16, 2010, 08:39
Robert
rob3rt is on a distinguished road
Hi Marcin,
I have a problem with kEpsilonCoeffs. I randomly selected some numbers (i.e. 0.09, 0.14, -0.33, etc.....) and it generates this error:
Selecting incompressible transport model Newtonian
Selecting RAS turbulence model kEpsilon
--> FOAM FATAL ERROR:
Attempt to return primitive entry ITstream : ::kEpsilonCoeffs, line 19, IOstream: Version 2.0, format ASCII, line 0, OPENED, GOOD
primitiveEntry 'kEpsilonCoeffs' comprises
on line 19 the doubleScalar -0.33
as a sub-dictionary
From function const dictionary& primitiveEntry::dict()
in file db/dictionary/primitiveEntry/primitiveEntry.C at line 107.
FOAM aborting
#0 Foam::error:rintStack(Foam::Ostream&) in "/home/roberto/OpenFOAM/OpenFOAM-1.6.x/lib/linux64GccDPOpt/libOpenFOAM.so"
#1 Foam::error::abort() in "/home/roberto/OpenFOAM/OpenFOAM-1.6.x/lib/linux64GccDPOpt/libOpenFOAM.so"
#2 Foam:rimitiveEntry::dict() in "/home/roberto/OpenFOAM/OpenFOAM-1.6.x/lib/linux64GccDPOpt/libOpenFOAM.so"
#3 Foam::dictionary::subDict(Foam::word const&) in "/home/roberto/OpenFOAM/OpenFOAM-1.6.x/lib/linux64GccDPOpt/libOpenFOAM.so"
#4 Foam::boussinesq::RASModel::RASModel(Foam::word const&, Foam::GeometricField<Foam::Vector<double>, Foam::fvPatchField, Foam::volMesh> const&, Foam::GeometricField<double, Foam::fvsPatchField, Foam::surfaceMesh> const&, Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh> const&, Foam::transportModel&) in "/home/roberto/OpenFOAM/OpenFOAM-1.6.x/lib/linux64GccDPOpt/libboussinesqRASModels.so"
#5 Foam::boussinesq::RASModels::kEpsilon::kEpsilon(Fo am::GeometricField<Foam::Vector<double>, Foam::fvPatchField, Foam::volMesh> const&, Foam::GeometricField<double, Foam::fvsPatchField, Foam::surfaceMesh> const&, Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh> const&, Foam::transportModel&) in "/home/roberto/OpenFOAM/OpenFOAM-1.6.x/lib/linux64GccDPOpt/libboussinesqRASModels.so"
#6 Foam::boussinesq::RASModel::adddictionaryConstruct orToTable<Foam::boussinesq::RASModels::kEpsilon>:: New(Foam::GeometricField<Foam::Vector<double>, Foam::fvPatchField, Foam::volMesh> const&, Foam::GeometricField<double, Foam::fvsPatchField, Foam::surfaceMesh> const&, Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh> const&, Foam::transportModel&) in "/home/roberto/OpenFOAM/OpenFOAM-1.6.x/lib/linux64GccDPOpt/libboussinesqRASModels.so"
#7 Foam::boussinesq::RASModel::New(Foam::GeometricFie ld<Foam::Vector<double>, Foam::fvPatchField, Foam::volMesh> const&, Foam::GeometricField<double, Foam::fvsPatchField, Foam::surfaceMesh> const&, Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh> const&, Foam::transportModel&) in "/home/roberto/OpenFOAM/OpenFOAM-1.6.x/lib/linux64GccDPOpt/libboussinesqRASModels.so"
in "/home/roberto/OpenFOAM/OpenFOAM-1.6.x/applications/bin/linux64GccDPOpt/my_porousSimpleFoam8"
#9 __libc_start_main in "/lib/libc.so.6"
Aborted
Do you have any suggestions??
Thanks very much in advance.
rob3rt is offline   Reply With Quote
Old   January 16, 2011, 10:18
Default compressible Launder Sharma k-e model
Dmitry
DimaZ is on a distinguished road
Hi all,
Does anybody know the reference for the implementation of the compressible k-e Launder Sharma k-epsilon model in OpenFOAM?
The incompressible formulation follows: Launder, B. E. and Sharma, B. I. (1974), "Application of the Energy-Dissipation Model of Turbulence to the Calculation of Flow Near a Spinning Disc", Letters in Heat and Mass Transfer, Vol. 1, No. 2, pp. 131-138.
But in the compressible implementation there is the constant CEpsilon3 and I'm just wondering about the reference for it.
Thanks in advance,
Dmitry
DimaZ is offline   Reply With Quote
Old   July 1, 2011, 09:06
The True
Eren10 is on a distinguished road
I want to use the incompressible case, but I see also there a C3 -0.33; I can't see this value in the paper of Launder ans Sharma. Did they introduced this term later ?
And is there a tutorial of LaunderSharma ? I want to see the required files.
Thanks.
Eren10 is offline   Reply With Quote
Old   July 4, 2011, 03:37
Dmitry
Thanks.
I did not find any. Regarding the tutorials and files: I can send you one of my own test cases, witch are validated, documented and published.
Best regards,
Dmitry
Old   July 19, 2013, 04:48
Default Need some explanation on kEpsilon.C
  #12
RJ HO
RJ87 is on a distinguished road
Hi foamers,
I check through kEpsilon.C file and don't quite understand how
 tmp<fvScalarMatrix> epsEqn
        fvm::ddt(rho_, epsilon_)
      + fvm::div(phi_, epsilon_)
      - fvm::Sp(fvc::ddt(rho_) + fvc::div(phi_), epsilon_)
      - fvm::laplacian(DepsilonEff(), epsilon_)
        C1_*G*epsilon_/k_
      - fvm::SuSp(((2.0/3.0)*C1_ + C3_)*rho_*divU, epsilon_)
      - fvm::Sp(C2_*rho_*epsilon_/k_, epsilon_)
why is the dissipative term is (- fvm::SuSp(((2.0/3.0)*C1_ + C3_)*rho_*divU, epsilon_)) instead of (- fvm::SuSp(((2.0/3.0)*C1_ - C3_)*rho_*divU, epsilon_).
I look through turbulence papers indicating that usage -((2.0/3.0)*C1-C3) with C3 assigned with negative value between 0 to 1 with the whole dissipative term a negative value. OpenFoam -((2.0/3.0)*C1+C3) with constant C3 assign with negative value of -0.33. In this case, if C3 is large enough, dissipative term will be a positive value. Any chances that something is wrong with the codes?
atulkjoy and ShaneheSSSS like this.
RJ87 is offline   Reply With Quote
Old   June 12, 2014, 01:33
Fabian E.
galap is on a distinguished road
I have a question which goes in the same direction. Why is actually in the compressible kEpsilon model equation the constant C3 included in this way? For me, I don't understand why C3 contributes to the reynolds shear stress term, which does not follow the standard formulation according to
http://www.cfd-online.com/Wiki/Standard_k-epsilon_model
or books from e.g. Pope and Poisnot
C3 should be the constant for source due to buoyancy.
C1_*G*epsilon_/k_
I would exspect something like
- fvm::SuSp(((2.0/3.0)*C1_)*rho_*divU, epsilon_) + C3_*(..)
galap is offline   Reply With Quote
Old   December 16, 2014, 06:07
Retired Super Moderator
Bruno Santos
Greetings to all!
Sorry for the necro-bump, but the CFD-Online forums follow the principle of using a thread on the same topic to keep things on-topic, and there are some news about this question:
Just in case something happens to the internet, the reference added was this one:
    Reference:
        "k-epsilon equations for compressible reciprocating engine flows"
        El Tahry, S. H.,
        AIAA Journal of Energy 7 (1983), 345-353.
Best regards,
Bruno
Old   March 19, 2017, 23:54
fumiya's Avatar
Fumiya Nozaki
fumiya is on a distinguished road
There has been an update to this topic:
https://bugs.openfoam.org/view.php?id=2496
https://github.com/OpenFOAM/OpenFOAM...d9e4ffcdef2392
Best regards,
Fumiya
wyldckat likes this.
[Personal]
fumiya is offline   Reply With Quote
Old   November 11, 2018, 11:22
gu1
Guilherme
gu1 is on a distinguished road
Could anyone explain to me why constant C1 is multiplied twice (as marked in bold below)? To my understanding, it would only be necessary to multiply once...
C1_*G*epsilon_/k_
By the way, can I end up with the constant C3 without fear of messing with my solution?! I think so, but...
New:
C1_*G*epsilon_/k_
- fvm::SuSp((2.0/3.0)*rho_*divU, epsilon_)
gu1 is offline   Reply With Quote
Old   November 11, 2018, 17:14
Bruno Santos
Quick answer: My guess is that this is related to the same paper from which the C3 term came from, because the 2/3 factor is also not found on most standard k-epsilon formulations.
gu1 likes this.
Simulation of a single bubble with a VOF-method Suzzn CFX 21 January 29, 2018 00:58
Reynolds Stress model in CFX vs Fluent Tim CFX 1 October 7, 2009 06:19
No results for solid domain Gary Holland CFX 10 March 13, 2009 03:30
Steam Diffusion Coefficient - Mixture model Graham Brett FLUENT 0 February 21, 2008 17:32
Reflection coefficient of particle in DPM model S.J.R FLUENT 1 June 9, 2007 19:03
