problem with running parafoam & paraview
Old   June 10, 2009, 03:05
Exclamation problem with running parafoam & paraview
padhu
padmanathan is on a distinguished road
i have installed openfoam completely and i tried openfoam cavity tutorial .
i can able to execute upto icofoam but while running paraFoam, the following error message is coming.
/usr/lib/paraview/paraview-real: error while loading shared libraries: /usr/lib/libOSMesa.so.6: cannot restore segment prot after reloc: Permission denied
i'm using fedora core 10, 32bit.
pls help me
padmanathan is offline   Reply With Quote
Old   June 10, 2009, 09:24
lin
Hua Zen
lin is on a distinguished road
This seems to be a SELINUX problem. Either you disable it, or run :
chcon -t texrel_shlib_t /usr/lib/libOSMesa.so.6
lin is offline   Reply With Quote
Old   June 11, 2009, 07:54
padhu
thank you lin, after disabling SElinux, the paraview is working properly.
thanks a lot
Old   June 12, 2009, 07:30
Default error while running paraFoam!
padhu
i'm trying lid-driven cavity flow exercise, while executing paraFoam, parafoam shows the following error, i don't know what is this? how can I resolve and proceed further? pls help me.
vtkPVDReader (0xa6546b8): Could not read file information
ERROR: In /builddir/build/BUILD/ParaView-3.4.0/VTK/Filtering/vtkExecutive.cxx, line 757
vtkCompositeDataPipeline (0xa062480): Algorithm vtkPVDReader(0xa6546b8) returned failure for request: vtkInformation (0x9f84480)
Debug: Off
Modified Time: 78270
Reference Count: 1
Registered Events: (none)
Request: REQUEST_DATA_OBJECT
ALGORITHM_AFTER_FORWARD: 1
FORWARD_DIRECTION: 0
parafoam, paraview
[OpenFOAM] Problem with paraview and paraFoam openfoam_user ParaView 36 May 13, 2014 07:37
Problem running paraFoam on OpenFOAM 1.5 sonny OpenFOAM 3 June 6, 2009 20:24
[OpenFOAM] Problem with Colors in ParaView sven ParaView 1 May 31, 2009 08:13
[OpenFOAM] paraFoam, problem loading 'volume fields' bigphil ParaView 0 April 29, 2009 09:36
Problem with running FoamX in a distributed environment susana OpenFOAM Pre-Processing 1 March 28, 2007 17:11
