Hi all,
does anybody know how to impose a non-uniform deformation to an oscillating plate? i've been trying to use the oscillatingDisplacement boundary condition but it seems not to support a non-uniform displacement of the patch points. Thanks in advance! |
Hey guys! check this out http://www.tfd.chalmers.se/~hani/kurser/OS_CFD_2008/
I found what i needed in Eysteinn Helgason's work. keep up the good work guys! |
xinguang cui
Rep Power: 17 ![]() |
Dear Gricci:
I also need to conduct the same kind work as you. Have you solved this problem? Would u please give me some hints on it? Thanks and best regards! Last edited by flying; October 5, 2012 at 07:45. Reason: mISS WORD |
Hi folks,
thank you for your interest in my work, but unfortunately I'm not working in the field of CFD from way back and I cannot help you. However I do remember that the link above has much of the information I needed! Good luck |
xinguang cui
Dear Gricci:
Thanks for your reply. As you suggested, I have referenced Eysteinn Helgason's work of Point-wise deformation of mesh patches. But, it is pity, I didn't understand it totally. How does make the deformation amtiputde changing with time? From the function of for instance, Z= Ax**2+By**2. It can not find time, but I find the deformation changes in one period. Another question is whether x, y is same location as the initial location in the patch. Thanks for so much! Best wishes! |
Convection discretization schemes for LES | sek | OpenFOAM Running, Solving & CFD | 38 | July 31, 2017 14:30 |
Pressure instability with rhoSimpleFoam | daniel_mills | OpenFOAM Running, Solving & CFD | 44 | February 17, 2011 17:08 |
FOAM FATAL IO ERRORsimpleFoam | hariya03 | OpenFOAM Running, Solving & CFD | 6 | July 16, 2008 08:03 |
RasInterFoam STRANGE RESULTS AT BOUNDARY | kumar2 | OpenFOAM Running, Solving & CFD | 8 | March 24, 2008 18:38 |
uniform grid and beta clustering | rvndr | Main CFD Forum | 0 | February 21, 2004 23:19 |
