non-uniform oscillatingDisplacement
Old   July 20, 2009, 11:52
Default non-uniform oscillatingDisplacement
Giovanni Ricci
gricci is on a distinguished road
Send a message via Skype™ to gricci
does anybody know how to impose a non-uniform deformation to an oscillating plate?
i've been trying to use the oscillatingDisplacement boundary condition but it seems not to support a non-uniform displacement of the patch points.
Thanks in advance!
gricci is offline   Reply With Quote
Old   July 22, 2009, 14:14
Giovanni Ricci
Hey guys! check this out http://www.tfd.chalmers.se/~hani/kurser/OS_CFD_2008/
I found what i needed in Eysteinn Helgason's work.
keep up the good work guys!
Old   October 5, 2012, 07:44
xinguang cui
flying is on a distinguished road
Dear Gricci:
I also need to conduct the same kind work as you. Have you solved this problem? Would u please give me some hints on it?
Thanks and best regards!
flying is offline   Reply With Quote
Old   October 6, 2012, 15:18
Giovanni Ricci
Hi folks,
thank you for your interest in my work, but unfortunately I'm not working in the field of CFD from way back and I cannot help you. However I do remember that the link above has much of the information I needed!
Good luck
Old   October 7, 2012, 21:57
xinguang cui
Dear Gricci:
Thanks for your reply. As you suggested, I have referenced Eysteinn Helgason's work of
Point-wise deformation of mesh patches. But, it is pity, I didn't understand it totally. How does make the deformation amtiputde changing with time?
From the function of for instance, Z= Ax**2+By**2. It can not find time, but I find the deformation changes in one period. Another question is whether x, y is same location as the initial location in the patch.
Thanks for so much!
Best wishes!
Convection discretization schemes for LES sek OpenFOAM Running, Solving & CFD 38 July 31, 2017 14:30
Pressure instability with rhoSimpleFoam daniel_mills OpenFOAM Running, Solving & CFD 44 February 17, 2011 17:08
FOAM FATAL IO ERRORsimpleFoam hariya03 OpenFOAM Running, Solving & CFD 6 July 16, 2008 08:03
RasInterFoam STRANGE RESULTS AT BOUNDARY kumar2 OpenFOAM Running, Solving & CFD 8 March 24, 2008 18:38
uniform grid and beta clustering rvndr Main CFD Forum 0 February 21, 2004 23:19
