August 14, 2009, 08:41 |
Issues with OpenFoam
Sanjib Das Sharma
Rep Power: 16 |
I am new to OpenFoam, however have been using FLUENT for a long time. To start a new project in OpenFoam, I thought it might be good to compare a benchmark case between OpenFoam and FLUENT. So, I took turbulent flow over a BACKWARD FACING STEP. Following are my conclusions: 1) Substantial difference in the velocity, turbulent-kinetic-energy and turbulent-dissipation fields. 2) The reattachment length is shorter in OPENFOAM prediction; While there are two circulation zones, top and bottom of the jet, predicted by OPENFOAM, there is only one predicted by FLUENT, the bottom one. 3) While I can use higher order discretization schemes in FLUENT, in OpenFoam I can use only "upwind" which is a first-order, bounded scheme. When I used 2nd order schemes, the results showed instability and no convergence was achieved. Does this mean we have to use only "upwind" and cannot use the higher order schemes ? 4) I also wanted to test the linear solvers by replacing default PCG/PBiCG with GAMG. However, this did not work and the simulation stopped abruptly. Does this mean we can use only PCG/PBiCG ? These are critical to my project and would help immensely to understand how OpenFoam works. Regards, Sanjib |
Superlinear speedup in OpenFOAM 13 | msrinath80 | OpenFOAM Running, Solving & CFD | 18 | March 3, 2015 05:36 |
[OpenFOAM] ParaView-3.7.0(cvs) + OpenFOAM Reader issues | philippose | ParaView | 15 | February 15, 2010 04:49 |
Modified OpenFOAM Forum Structure and New Mailing-List | pete | Site News & Announcements | 0 | June 29, 2009 05:56 |
OpenFOAM 15 and CentOS 52 installation issues | remrich | OpenFOAM Bugs | 9 | March 20, 2009 01:48 |
OpenFOAM Debian packaging current status problems and TODOs | oseen | OpenFOAM Installation | 9 | August 26, 2007 13:50 |
