Hi Foamers!
Old   August 10, 2009, 12:02
Default Hi Foamers!
Primoz Ternik
ternik is on a distinguished road
although that I am quite "fresh" in OpenFoam, I found out that it is pretty powerful and it is gaining on popularity. But on the other hand I am missing the capability to use (prescribe) the combination of "zero gradient" and "mass flow rate" boundary conditions at inlets (or at outlets)! So, do you know someone that has already (or is willing and able) wrote down small piece of program for this? Unfortunately my knowledge in C++ is extremely low...
Of course one can overcome this by modeling long enough "inlet section"(but this can be quite "computer memory" consuming, especially for higher values of Re number) or by prescribing fully developed values for velocity, etc. (but this is known only for Newtonian as well as some basic non-Newtonian fluid models and not for Carreau-Yasuda or some other "industrially" interesting non-Newtonian models)!
ternik is offline   Reply With Quote
Old   August 12, 2009, 07:01
Smile Mass Flow Rate And Zero Gradient
Primoz Ternik
In order to "push a bit" my previous post, I will explain "why and what":
  • there are numerous numerical examples (either for validation purposes or calculating something new) that requires fully developed flow conditions at inlets for particular flow field; e.g. velocity, pressure, now with OpefFoam.1.5-dev even for viscoelastic shear stresses
  • currently, there are following possibilities for this
    • defining theoretical profiles for particular flow field, but this is (most likely) limited to Newtonian and some "simple" non-Newtonian (Power law) fluids
    • taking the advantage of pressureInletVelocity boundary conditions (defining pressure at inlet and outlet), but this (pressure drop) on the other hand is not always known!
    • defining the average velocity at inlet and then model "long-enough" section to obtain fully developed conditions, which I find extremely "computer memory & time" consuming
So, it is my strong opinion, that modelling of fully developed inflow conditions with a combination of mass flow rate and zero gradients for particular flow variable would not be only of great interest (for both, steady and transient flow) but would also reduce unnecessary "computer memory & time" consumption!
Unfortunately, I am rather fresh to OpenFoam and C++ and therefore I kindly ask "is there anybody out there" that is willing to hear "my cry for help".
Enjoy the day,
Primoz.
Old   October 26, 2010, 11:35
maysmech's Avatar
maysmech is on a distinguished road
I have problem to define mass flow rate B.C too. Any suggestion will be appreciated.
maysmech is offline   Reply With Quote
boundary conditions, mass flow rate, zero gradient
Where to find the theory for weller flamet combustion model 21kalee OpenFOAM Running, Solving & CFD 7 December 19, 2012 17:18
Torque in a sliding interface mesh antonio_ing OpenFOAM Running, Solving & CFD 8 February 23, 2009 04:58
Is it possible to obtain wallY%23601 for an airfoil dinonettis OpenFOAM Running, Solving & CFD 3 May 28, 2008 04:25
To respected Henry weller and Foamers who use combustion in openfoam 21kalee OpenFOAM Running, Solving & CFD 0 December 29, 2007 07:36
Newbie compiling source code for debugging unoder OpenFOAM Running, Solving & CFD 8 August 24, 2006 01:41
