Flow Around a Cylinder
Old   August 30, 2009, 02:45
Default Flow Around a Cylinder
toto
ronaldo is on a distinguished road
I am trying to model a flow around a cylinder 2D using simpleFoam.The Velocity is 3m/s and The turbulence model is k-epsilon Standard.
The dimension of the cylinder is 0.1 m diameter.
How could i set the Boundary Condition for Wall- Top and Bottom to get no Slip?
What about the Cylinder-Wall?
Please it ist very important for me and I would greatly appreciate it if you could send me an Answer or a case like that.
ronaldo is offline   Reply With Quote
Old   August 30, 2009, 16:10
Steve Hansel
hansel is on a distinguished road
In the boundaryField section of your first U file you would have something like:
minY
type fixedValue;
value uniform (0 0 0);
where minY is what ever name you gave your sides and / or the cylinder-wall.
See the tutorials for more examples.
hansel is offline   Reply With Quote
Old   August 31, 2009, 03:51
toto
Thanks Hansel!
My Boundary Condition and so on look like:
FoamFile
version 2.0;
format ascii;
class volVectorField;
object U;
dimensions [0 1 -1 0 0 0 0];
internalField uniform (0 0 0);
boundaryField
Rohrwand
type fixedValue;
Outlet_Pres
type zeroGradient;
Inlet_Vel
type fixedValue;
value uniform (2 0 0);
Sym_Wand
type symmetry;
frontAndBackPlanes
type empty;
dimensions [0 2 -2 0 0 0 0];
internalField uniform 0;
boundaryField
Rohrwand
type zeroGradient; ;
Outlet_Pres
type fixedValue;
value uniform 0;
Inlet_Vel
type zeroGradient;
Sym_Wand
type symmetry;
frontAndBackPlanes
type empty;
FoamFile
version 2.0;
format ascii;
class volScalarField;
location "0";
object k;
internalField uniform 0.87;
boundaryField
Rohrwand
type zeroGradient;
Outlet_Pres
type zeroGradient;
Inlet_Vel
type fixedValue;
value uniform 0.87;
Sym_Wand
type symmetry;
frontAndBackPlanes
type empty;
FoamFile
version 2.0;
format ascii;
location "0";
object epsilon;
dimensions [0 2 -3 0 0 0 0];
internalField uniform 8579.621;
boundaryField
Rohrwand
type zeroGradient;
Outlet_Pres
type zeroGradient;
Inlet_Vel
type fixedValue;
value uniform 8579.621;
Sym_Wand
type symmetry;
frontAndBackPlanes
type empty;
dimensions [0 2 -1 0 0 0 0];
boundaryField
Rohrwand
type nutWallFunction;
Cmu 0.09;
kappa 0.41;
E 9.8;
value uniform 0;
Outlet_Pres
type calculated;
value uniform 0;
Inlet_Vel
type calculated;
value uniform 0;
Sym_Wand
type calculated;
value uniform 0;
frontAndBackPlanes
type empty;
FoamFile
version 2.0;
format ascii;
class volSymmTensorField;
object R;
internalField uniform (0 0 0 0 0 0);
boundaryField
Rohrwand
type zeroGradient;
Outlet_Pres
type zeroGradient;
Inlet_Vel
type fixedValue;
value uniform (0 0 0 0 0 0 0);
Sym_Wand
type symmetry;
frontAndBackPlanes
type empty;
FoamFile
version 2.0;
format ascii;
class polyBoundaryMesh;
location "constant/polyMesh";
object boundary;
5(
Rohrwand
type wall;
physicalType wallFunctions;
nFaces 100;
startFace 182530;
Outlet_Pres
type patch;
physicalType outlet;
nFaces 300;
startFace 182630;
Inlet_Vel
type patch;
physicalType inlet;
nFaces 100;
startFace 182930;
Sym_Wand
type symmetryPlane;
nFaces 700;
startFace 183030;
frontAndBackPlanes
type empty;
nFaces 183130;
startFace 183730;
FoamFile
version 2.0;
format ascii;
class dictionary;
location "constant";
object RASProperties;
RASModel kEpsilon;
turbulence on;
printCoeffs on;
FoamFile
version 2.0;
format ascii;
class dictionary;
object transportProperties;
transportModel Newtonian;
nu nu [0 2 -1 0 0 0 0] 1.46e-05;
CrossPowerLawCoeffs
nu0 nu0 [0 2 -1 0 0 0 0] 0;
nuInf nuInf [0 2 -1 0 0 0 0] 0;
m <> [0 0 0 0 0 0 0] 0;
n <> [0 0 0 0 0 0 0] 0;
BirdCarreauCoeffs
k <> [0 0 0 0 0 0 0] 0;
FoamFile
version 2.0;
format ascii;
object nuTilda;
boundaryField
Rohrwand
type zeroGradient;
Outlet_Pres
type zeroGradient;
Inlet_Vel
type fixedValue;
value uniform 0;
Sym_Wand
type symmetry;
frontAndBackPlanes
type empty;
FoamFile
version 2.0;
format ascii;
class dictionary;
location "system";
object fvSolution;
turbulenceModel kEpsilon;
turbulence on;
laminarCoeffs
kEpsilonCoeffs
Cmu Cmu [0 0 0 0 0 0 0] 0.09;
C1 C1 [0 0 0 0 0 0 0] 1.44;
C2 C2 [0 0 0 0 0 0 0] 1.92;
alphaEps alphaEps [0 0 0 0 0 0 0] 0.76923;
I get this Error when i start the Simulation: Inconsistent Patch and patchField types for patch type symmetryPlane and patchField type symmety
When i change SymmetryPlane to slip or Wall , my solution is absurdity.
I need Help please!
Old   August 31, 2009, 09:29
Default symmetry should be symmetryPlane
gocarts's Avatar
Richard Smith
gocarts is on a distinguished road
Judging by your error message I think you need to replace:
Sym_Wand
type symmetry;
with:
Sym_Wand
type symmetryPlane;
within your case/0/* field files.
Symscape, Computational Fluid Dynamics for all
gocarts is offline   Reply With Quote
Old   September 14, 2009, 11:25
Steve Hansel
I think the units on k are supposed to be [0 0 1 0 0 0 0]
and m [0 0 1 0 0 0 0]
Old   September 18, 2009, 08:13
toto
It is the units on omega! The units on k is [0 2 -2 0 0 0 0 ]
benchmark: flow over a circular cylinder goodegg Main CFD Forum 12 January 22, 2013 11:47
Flow over a flat plate & Flow over a cylinder cfdxue Main CFD Forum 0 November 26, 2007 23:26
Anybody knows smth abt the flow around a cylinder? Wenxuan Main CFD Forum 3 March 20, 2007 16:19
Flow over a cylinder Anna Main CFD Forum 9 March 24, 2006 14:32
Flow Past a Cylinder Annie Main CFD Forum 2 March 31, 2002 00:02
