beginner-hlp pls
Old   September 29, 2009, 22:52
Default beginner-hlp pls
sarangarajan
sarajags_89 is on a distinguished road
hi guys i want to set a pressuer of 2 units in movingwall1 and 1 in movingwall .. am getting an error in this could you guys help me with it?
| \\ / O peration | Version: 1.6 |
| \\ / A nd | Web: http://www.OpenFOAM.org |
| \\/ M anipulation | |
FoamFile
version 2.0;
format ascii;
class volScalarField;
object p;
dimensions [0 2 -2 0 0 0 0];
internalField uniform 0;
boundaryField
movingWall
type fixedValue;
value uniform (1 0 0);
movingWall1
type fixedValue;
value uniform (2 0 0);
fixedWalls
type zeroGradient;
frontAndBack
type empty;
sarajags_89 is offline   Reply With Quote
Old   September 30, 2009, 00:40
Alberto Passalacqua
FoamFile
version 2.0;
format ascii;
object p;
boundaryField
movingWall
type fixedValue;
movingWall1
type fixedValue;
fixedWalls
type zeroGradient;
frontAndBack
type empty;
A pressure is a scalar, not a vector, so don't use (1 0 0) but simply 1.
However, why do you specify the pressure at a wall, since if you use the no-slip condition, you already specify the velocity, and the pressure should be set to zeroGradient.
Best,
Alberto Passalacqua
Old   September 30, 2009, 13:27
Default @ alberto
sarangarajan
Thanks for the reply. Actually I am modifying the cavity problem in the tutorial. I am keeping one face as inlet and the other as outlet. So I named one face of the face as movingwall and an opposite face as movingwall1. I then specified pressure difference as well as velocity difference is this right
Old   September 30, 2009, 13:38
Alberto Passalacqua
You should specify velocity at the inlet, where p is set to zeroGradient, and pressure at the outlet, where velocity is set to zeroGradient. Keep in mind you consider incompressible flows.
Alberto Passalacqua
Old   September 30, 2009, 17:09
Default @alberto
sarangarajan
hi.. I understood what you said.. my question is how do i differentiate vectors and scalars when I type them in the editor
hope this is clear
for pressure
movingWall
type fixed;
value 0;
is this correct?
Old   September 30, 2009, 19:55
Alberto Passalacqua
hope this is clear
for pressure
movingWall
type fixed;
value 0;
is this correct?
No it is not correct.
movingWall
type fixedValue;
value uniform 0;
is the right syntax. This should be clear by all the examples you find in the tutorials.
Best,
Alberto Passalacqua
Old   September 30, 2009, 19:56
Alberto Passalacqua
Please, don't lie at us.
>my question is how do i type vectors scalars
'v' 'e' 'c' 't' 'o' 'r' 's' 's' 'c' 'a' 'l' 'a' 'r' 's'
>what is uniform(0 0 0) mean?..
The mean of uniform(0 0 0) is (0 0 0).
You should check your '.' key. It is typing itself in places, where it makes as little sense as the rest of the questions.
Maybe next time you can save your time, and do not reply at all.
Alberto Passalacqua
i need help following problem pls pls help gmani CFX 4 March 31, 2009 09:39
Turbulence model for subsea stability, Pls. Abiodun FLUENT 1 August 23, 2007 06:52
Pls. help with particle tracking Daddy CFX 4 August 16, 2007 04:34
multi phase flows....pls help... karthik FLUENT 0 November 16, 2005 09:15
help pls gianluca FLUENT 2 November 12, 2004 10:27
