rhoSimpleFoam & rhoPisoFoam
Old   October 7, 2009, 05:38
Default rhoSimpleFoam & rhoPisoFoam
toto
ronaldo is on a distinguished road
could someone tell me what this Error means!
It is very important!
Thank you in advance.
Create time
Create mesh for time = 0
Reading thermophysical properties
Selecting thermodynamics package
hPsiThermo<pureMixture<constTransport<specieThermo <hConstThermo<perfectGas>>>>>
Reading field U
Creating turbulence model
Selecting turbulence model type RASModel
Selecting RAS turbulence model kOmegaSST
#0 Foam::error:rintStack(Foam::Ostream&) in
"/home/student/OpenFOAM/OpenFOAM-1.6/lib/linux64GccDPOpt/libOpenFOAM.so"
#1 Foam::sigFpe::sigFpeHandler(int) in
#2 ?? in "/lib64/libc.so.6"
#3 Foam::divide(Foam::Field<double>&, Foam::UList<double> const&, Foam::UList<double>
const&) in "/home/student/OpenFOAM/OpenFOAM-1.6/lib/linux64GccDPOpt/libOpenFOAM.so"
#4 void Foam::divide<Foam::fvPatchField, Foam::volMesh>(Foam::GeometricField<double,
Foam::fvPatchField, Foam::volMesh>&, Foam::GeometricField<double, Foam::fvPatchField,
Foam::volMesh> const&, Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh>
const&) in "/home/student/OpenFOAM/OpenFOAM-1.6/lib/linux64GccDPOpt/libfiniteVolume.so"
#5 Foam::tmp<Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh> >
Foam:perator/<Foam::fvPatchField, Foam::volMesh>(Foam::GeometricField<double,
Foam::fvPatchField, Foam::volMesh> const&, Foam::GeometricField<double, Foam::fvPatchField,
Foam::volMesh> const&) in
#6 Foam::compressible::RASModels::kOmegaSST::F2() const in
"/home/student/OpenFOAM/OpenFOAM-1.6/lib/linux64GccDPOpt/libcompressibleRASModels.so
#7 Foam::compressible::RASModels::kOmegaSST::kOmegaSS T(Foam::GeometricField<double,
Foam::fvPatchField, Foam::volMesh> const&, Foam::GeometricField<Foam::Vector<double>,
Foam::fvsPatchField, Foam::surfaceMesh> const&, Foam::basicThermo const&) in
Foam::compressible::RASModel::adddictionaryConstru ctorToTable<Foam::compressible::RASMo
dels::kOmegaSST>::New(Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh>
const&, Foam::GeometricField<Foam::Vector<double>, Foam::fvPatchField, Foam::volMesh>
const&, Foam::GeometricField<double, Foam::fvsPatchField, Foam::surfaceMesh> const&,
#9 Foam::compressible::RASModel::New(Foam::GeometricF ield<double, Foam::fvPatchField,
Foam::volMesh> const&, Foam::GeometricField<Foam::Vector<double>, Foam::fvPatchField,
Foam::volMesh> const&, Foam::GeometricField<double, Foam::fvsPatchField,
Foam::compressible::turbulenceModel::addturbulence ModelConstructorToTable<Foam::compressi
ble::RASModel>::NewturbulenceModel(Foam::Geometric Field<double, Foam::fvPatchField,
#11 Foam::compressible::turbulenceModel::New(Foam::Geo metricField<double,
"/home/student/OpenFOAM/OpenFOAM-1.6/lib/linux64GccDPOpt/libcompressibleTurbulenceMo
del.so"
#12 main in
"/home/student/OpenFOAM/OpenFOAM-1.6/applications/bin/linux64GccDPOpt/rhoPisoFoam"
#13 __libc_start_main in "/lib64/libc.so.6"
#14 _start at /usr/src/packages/BUILD/glibc-2.9/csu/../sysdeps/x86_64/elf/start.S:116
Gleitkomma-Ausnahme
ronaldo is offline   Reply With Quote
Old   October 7, 2009, 05:46
ngj
Niels Gjoel Jacobsen
ngj will become famous soon enoughngj will become famous soon enough
You are dividing by zero in your turbulence model. The problem is that you have specified 0 as internal or boundary value on either k or omega. Use something like 1e-11 instead.
Best regards,
Niels
ngj is offline   Reply With Quote
Old   October 7, 2009, 07:15
toto
Thank you Niels!
I did it but problem remains! More ideas please?
Thanks!
TRANSONIC FLOW in RHOSIMPLEFOAM dinonettis OpenFOAM Running, Solving & CFD 10 September 13, 2018 10:22
RhoSimpleFoam tutorial test case system dictionaries flavio_pergolesi OpenFOAM Running, Solving & CFD 2 April 17, 2014 08:41
RhoSimpleFoam FoamX spv24 OpenFOAM Running, Solving & CFD 1 July 21, 2008 10:29
RhoSimpleFoam negative pressure gzink OpenFOAM Running, Solving & CFD 10 June 4, 2007 05:35
Stability startup problems with rhoSimpleFoam olesen OpenFOAM Running, Solving & CFD 1 July 18, 2006 08:09
