rhoSimpleFoam & buoyantFoam
Old   October 10, 2009, 04:49
Default rhoSimpleFoam & buoyantFoam
toto
ronaldo is on a distinguished road
I tried to simulate using rhoSimpleFoam and buoyantSimpleFoam, but I became following problems:
1. The Pressure Solver needs 1000 Iteration per Timestep
2. I canīt find the thermoType below under thermophysicalpropeties
thermoType hThermo<pureMixture<constTransport<specieThermo<hC onstThermo<perfectGas>>>>>;
- could someone send me a case simulated using rho- or buoyantSimpleFoam ?
- I would also like to know how to set alpha, mut, p, T under "0-Directory"
Thank you in advance (It is very important please!)
ronaldo is offline   Reply With Quote
Old   October 11, 2009, 07:45
tian's Avatar
Tian
tian is on a distinguished road
Hi Ronaldo,
maybe my case help you a little bit. It is for OpenFOAM Version 1.5-dev (bouyantSimpleFoam). It is a small room with 3 inlets and 3 outlets.
Your problem looks like a pressure boundary mistakes (1000 iterations).
http://rapidshare.com/files/291528070/raum.tgz.html
Bye
Tian
tian is offline   Reply With Quote
TRANSONIC FLOW in RHOSIMPLEFOAM dinonettis OpenFOAM Running, Solving & CFD 10 September 13, 2018 10:22
transient buoyantFoam including radiation? thomasduerr OpenFOAM 0 June 5, 2009 07:04
RhoSimpleFoam jphandrigan OpenFOAM Running, Solving & CFD 18 March 29, 2009 11:05
RhoSimpleFoam FoamX spv24 OpenFOAM Running, Solving & CFD 1 July 21, 2008 10:29
Stability startup problems with rhoSimpleFoam olesen OpenFOAM Running, Solving & CFD 1 July 18, 2006 08:09
