October 13, 2009, 06:10 |
fluentMeshToFoam
toto
could someone give any idea how to solve or obviate the following faeture of Openfoam? " Multiple Material meshes are not permitted. If multiple fluid material exist, they will be converted into a single OpenFoam mesh; if a solid region is detected , the converter will attempt to filter it out " I had this problem , when i tried to convert the mesh using fluentMeshToFoam. Thank you in advance Please Help! |
January 1, 2010, 10:18 |
santhosh
use fluent3DMeshToFoam, it automatically detects multiple fluid regions and writes the cellZones files in the polyMesh dictionary.
After doing that use splitMeshRegions -cellZones, which will create the new directory 0.001 in which mesh for multiple region kept in different directories. Regards Santosh |
[Commercial meshers] fluentMeshToFoam: "fluent patch type shadow not recognised" | preibie | OpenFOAM Meshing & Mesh Conversion | 28 | March 29, 2017 04:56 |
[Commercial meshers] Converting a mesh with splitted cells using fluentMeshToFoam | jlpelerin | OpenFOAM Meshing & Mesh Conversion | 4 | April 25, 2011 16:56 |
problem when converting mesh (made by ICEM) using fluentMeshToFoam | Forrest_Lei | OpenFOAM | 11 | October 16, 2009 06:28 |
[Commercial meshers] fluentMeshToFoam error | bucksfan | OpenFOAM Meshing & Mesh Conversion | 14 | October 13, 2009 05:00 |
[Commercial meshers] Error fluentMeshToFoam | loneboard | OpenFOAM Meshing & Mesh Conversion | 26 | February 6, 2009 10:20 |
