chtMultiRegionFOAM " Heattransfert"
Old   December 28, 2009, 12:59
Default chtMultiRegionFOAM " Heattransfert"
toto
ronaldo is on a distinguished road
I have tried to simulate an Heat Exchanger using " chtMultiRegionFoam (Air and solid)", but nothing append in the Solid. No heat transfer in the solid.
Could someone give a idea?
ronaldo is offline   Reply With Quote
Old   January 1, 2010, 10:08
santhosh
santoo_cfd is on a distinguished road
I suppose you might not given correct boundary conditions for the fluid and solid interface.
Try to look at the tutorial provided in the chtMultiRegion foam dictionary.
The T at interface should be solidWallMixedTemperatureCoupled. and you should also change the boundary patch to directMappedPatch.
If you do appropriate changes, you should get the temperature variation in solid region also.
Regards
Santosh...
santoo_cfd is offline   Reply With Quote
Problem with running chtMultiRegionFoam after using setSet utility Victor OpenFOAM 12 March 24, 2023 00:01
Problem setting with chtmultiregionFoam Antonin OpenFOAM 10 April 24, 2012 09:50
problems with probes() function in chtMultiRegionFoam Victor OpenFOAM 0 November 25, 2009 15:08
About chtMultiRegionFoam in parallel (v1.6) Zheng.Zhi OpenFOAM Bugs 10 November 16, 2009 12:46
Problem setting with chtmultiregionFoam Antonin OpenFOAM Running, Solving & CFD 3 July 20, 2009 06:52
