Is the fluent mesh generate in windows can be used in linux?
Old   October 15, 2009, 23:47
Smile Is the fluent mesh generate in windows can be used in linux?
Jiang
panda60 is on a distinguished road
Dear everybody!
I want to use fluentMeshToFoam.
my fluent msh is generated in windows system ,if it can ben used to OpenFoam in linux?
or I have to generate the msh in linux system?
I mean if the msh generated using the same software in different system, are the same ,too?
Thanks.
panda60 is offline   Reply With Quote
Old   October 16, 2009, 00:01
Default Yes
Eric Nutsch
ericnutsch is on a distinguished road
Send a message via Skype™ to ericnutsch
Yeah a question I can answer! ( im an OpenFoam newbee too)
Yes, it will work I have done it. Just transfer the mesh file to the linux system and use the fluentMeshToFoam utility you mentioned.
Good Luck! Let me know how it goes.
ericnutsch is offline   Reply With Quote
Old   October 16, 2009, 02:19
Jiang
Thank you ericnutsch .
I have tried.
The first time it displayed that: can't open file controlDict.
so I copy a arbitrary file from other directory to the system of this case.And it works. But I don't know if the new mesh is right. I want to know the function of the controlDict file? If I shoule write something in it?
Thank you.
Old   October 16, 2009, 03:22
Eric Nutsch
I think I may have had to do the same thing come to think of it. I viewed my mesh in paraview and it turned out well. Im not certian how all that controlDict stuff works yet either.
To test your mesh. Go to the directory it is in with the terminal using cd
Then type: paraFoam
If that doesnt work you may have to use foamToVTK to convert it to paraview format then manually open it with paraview.
The openfoam user manual has a pretty good walkthrough for viewing your mesh once you have made it that far.
Good luck!
Old   October 17, 2009, 00:35
Jiang
Then type: paraFoam
Good luck!
Dear ericnutsch,
Because my paraview always can not run in terminal, You means that I can download an independent ParaView, change data to VTK , and manually open it with paraview?
Thank you, I will try.
Old   October 17, 2009, 01:10
Eric Nutsch
You can download paraview independently or use the version that comes with foam. I believe typing "paraview" into the terminal should run it. My system is down or I would test it. It may be "paraView"
paraFoam is just a utility that switches the data around and presents it to paraview.
I could not get my parafoam to work, thus i utilize foamToVTK to build the file that I view from the paraview gui.
Once I get my system running again I might be able to provide some real instructions.
Good luck
Old   October 19, 2009, 05:31
Jiang
Good luck
Thank you very much.
Old   October 19, 2009, 11:51
Carl Berger
carl is on a distinguished road
I'm relatively new to openfoam too, nevertheless:
using a windows file under unix (linux) usually is posing
only problems in case of a text file, where the carriage
return symbol is different.
most of the input files are stored in text mode, and so
is the controlDict file, where the simulation procedure is
described (time step, Starttime, endtime, simulation
output etc.)
you will need to edit it anyway according to your case.
good luck, Carl
carl is offline   Reply With Quote
Exporting structured mesh from ICEMCFD to Fluent? jeevan kumar FLUENT 1 January 23, 2012 11:21
[ICEM] Unstructure Meshing Around Imported Plot3D Structured Mesh ICEM kawamatt2 ANSYS Meshing & Geometry 17 December 20, 2011 11:45
linux or windows for FLUENT users peter gelblum FLUENT 3 December 27, 2002 16:19
Help....WINDOWS 2000 platform to LINUX platform.. Jim Clancy FLUENT 1 March 5, 2002 03:23
unstructured vs. structured grids Frank Muldoon Main CFD Forum 1 January 5, 1999 10:09
