Can't simulate pressures over 80 bar in sonicFoam
Old   October 29, 2009, 07:24
Post Can't simulate pressures over 80 bar in sonicFoam
Dennis Rown
shangzung is on a distinguished road
Hello!
(sorry, I meant 900 bar, threshold value is : 89984650Pa)
Somehow with the sonicFoam I can not set the pressure in the setFields over 80.000.000 Pa without the simulation crashing. Is this something of a border?
Did someone ever simulated pressures around 1kbar?
shangzung is offline   Reply With Quote
Old   October 29, 2009, 23:18
Alberto Passalacqua
Originally Posted by shangzung View Post
Hello!
Error message?
Alberto Passalacqua
Old   October 30, 2009, 04:06
Dennis Rown
It does not simulate even one timestep. I have to add that I modified the sonicFoam.C for the adjustable timestep to work.
I get this error:
Creating turbulence model
Selecting turbulence model type laminar
Starting time loop
Time = 1e-12
Courant Number mean: 0 max: 0
deltaT = 1.2e-12
diagonal: Solving for rho, Initial residual = 0, Final residual = 0, No Iterations 0
DILUPBiCG: Solving for Ux, Initial residual = 1, Final residual = 1.50669e-16, No Iterations 1
DILUPBiCG: Solving for e, Initial residual = 6.66672e-16, Final residual = 6.66672e-16, No Iterations 0
#0 Foam::error:rintStack(Foam::Ostream&) in "/home/simulation/OpenFOAM/OpenFOAM-1.6/lib/linux64GccDPOpt/libOpenFOAM.so"
#1 Foam::sigFpe::sigFpeHandler(int) in "/home/simulation/OpenFOAM/OpenFOAM-1.6/lib/linux64GccDPOpt/libOpenFOAM.so"
#2 ?? in "/lib64/libc.so.6"
#3 Foam::LimitedScheme<double, Foam::limitedLinearLimiter<Foam::NVDTVD>, Foam::limitFuncs::magSqr>::limiter(Foam::Geometric Field<double, Foam::fvPatchField, Foam::volMesh> const&) const in "/home/simulation/OpenFOAM/OpenFOAM-1.6/lib/linux64GccDPOpt/libfiniteVolume.so"
#4 Foam::limitedSurfaceInterpolationScheme<double>::w eights(Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh> const&) const in "/home/simulation/OpenFOAM/OpenFOAM-1.6/lib/linux64GccDPOpt/libfiniteVolume.so"
#5 Foam::fv::gaussConvectionScheme<double>::fvmDiv(Fo am::GeometricField<double, Foam::fvsPatchField, Foam::surfaceMesh> const&, Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh>&) const in "/home/simulation/OpenFOAM/OpenFOAM-1.6/lib/linux64GccDPOpt/libfiniteVolume.so"
#6 Foam::tmp<Foam::fvMatrix<double> > Foam::fvm::div<double>(Foam::GeometricField<double , Foam::fvsPatchField, Foam::surfaceMesh> const&, Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh>&, Foam::word const&) in "/home/simulation/OpenFOAM/OpenFOAM-1.6/applications/bin/linux64GccDPOpt/sonicFoam"
#7 Foam::tmp<Foam::fvMatrix<double> > Foam::fvm::div<double>(Foam::GeometricField<double , Foam::fvsPatchField, Foam::surfaceMesh> const&, Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh>&) in "/home/simulation/OpenFOAM/OpenFOAM-1.6/applications/bin/linux64GccDPOpt/sonicFoam"
#8 main in "/home/simulation/OpenFOAM/OpenFOAM-1.6/applications/bin/linux64GccDPOpt/sonicFoam"
#9 __libc_start_main in "/lib64/libc.so.6"
#10 _start at /usr/src/packages/BUILD/glibc-2.9/csu/../sysdeps/x86_64/elf/start.S:116
Gleitkomma-Ausnahme
Old   October 30, 2009, 08:33
Dennis Rown
I found out that with the solver "rhopSonicFoam" the problem does not occur!
Old   October 30, 2009, 09:07
Chris Sideroff
cnsidero is on a distinguished road
Not an answer to your question but I am interested in getting adjustable timestep working in my solver. Would you be willing to share your adjustable timestep modifications to sonicFoam?
cnsidero is offline   Reply With Quote
Old   October 30, 2009, 09:51
Dennis Rown
Yeah, here's the code: (I use OF 1.6)
#include "fvCFD.H"
#include "basicPsiThermo.H"
#include "turbulenceModel.H"
int main(int argc, char *argv[])
#include "setRootCase.H"
#include "createTime.H"
#include "createMesh.H"
#include "createFields.H"
#include "initContinuityErrs.H"
#include "readTimeControls.H"
Info<< "\nStarting time loop\n" << endl;
while (runTime.loop())
Info<< "Time = " << runTime.timeName() << nl << endl;
#include "readPISOControls.H"
#include "CourantNo.H"
#include "setDeltaT.H"
#include "rhoEqn.H"
#include "UEqn.H"
#include "eEqn.H"
// --- PISO loop
for (int corr=0; corr<nCorr; corr++)
#include "pEqn.H"
turbulence->correct();
rho = thermo.rho();
runTime.write();
Info<< "ExecutionTime = " << runTime.elapsedCpuTime() << " s"
<< " ClockTime = " << runTime.elapsedClockTime() << " s"
<< nl << endl;
Info<< "End\n" << endl;
return 0;
Old   October 30, 2009, 10:21
Chris Sideroff
Oops sorry, I mistook "adjustable timestep" to be "local timstep". I am trying to implement a timestep that varies throughout the field dependent on the local Co.
energy in sonicFoam joern OpenFOAM Running, Solving & CFD 1 September 24, 2019 00:15
3-D Water Flow in Fluent to Evaluate Pressures ahammack FLUENT 2 September 1, 2009 22:41
Negative pressures in the flow domain mahut FLUENT 2 September 27, 2007 05:07
Guage vs. Absolute pressures in Fluent. Riaan FLUENT 1 January 21, 2005 14:22
What is best way to simulate big particle yueroo FLUENT 2 April 13, 2001 21:28
