parallel results different depending on decomposition strategy
Old   November 3, 2009, 10:52
Smile parallel results different depending on decomposition strategy
Francesco
franzisko is on a distinguished road
hello,
I performed a simulation using simpleFoam and for different parallelization strategies: number of processors, simple/hierarchical/... I get slightly different results. Is there anyone which knows it is ok, or if there is any problem. The difference seems to be small (more or less 1% on drag coefficient for the stationary solution). Where is the part depending on the decomposition method?
thanks a lot,
Francesco
franzisko is offline   Reply With Quote
Old   November 4, 2009, 03:07
Anonymous
madad2005 is on a distinguished road
Hi Francesco,
I've been having some wider-spread issues with using foam in parallel. I'm assuming the differences you are seeing are due to decomposition of the domain each time with different regions having different ghost cells. 1% does appear to be a lot though. Interestingly, I'm finding that when attempting to run foam in parallel, it appears it is trying to run N number of serial jobs and is killing the memory on my machine. Have you seen similar behaviour?
Regards,
Adriano
madad2005 is offline   Reply With Quote
Old   November 4, 2009, 05:35
Anonymous
Well, I finally resolved my problem. I was missing the -parallel command out when executing the parallel job.
Old   November 4, 2009, 06:37
Francesco
hi adriano,
thanks for your suggestion concerning ghost nodes. I think 1% is a bit too much, too. however, the fields are very similar each other, hence I hope there is no serious problem
intersting behaviour missing -parallel...
bye, francesco
error, parallel, results, simplefoam
Different Results from Fluent 5.5 and Fluent 6.0 Rajeev Kumar Singh FLUENT 6 December 19, 2010 11:33
MPICH Parallel Run Error on the Windows Server2003 Saturn CFX 3 August 29, 2006 08:42
results with parallel processing Muhammad Shakaib Main CFD Forum 1 December 29, 2005 00:56
CFX-5.7 MPICH Parallel Problem (Output of Results) James Date CFX 7 February 15, 2005 16:03
parallel mode - small problem? co2 FLUENT 2 June 1, 2004 23:47
