Relaxation Factor Influence
Old   November 5, 2009, 05:58
Default Relaxation Factor Influence
Benoit Bonnal
Benoit is on a distinguished road
Hi FOAMers,
I'm a new user of OpenFoam and I'm currently working on an airfoil in 2D.
When changing the relaxation factor, I have noticed that it also changed the final result so I have made a quick investigation on this problem.
The figure attached displays the drag coefficient computed by OpenFoam. I'm using simpleFoam and the only differences between these cases are the relaxation factors.
Though the differences are small, they do exist and this is certainly not something I was expecting.
Could anyone enlighten me ?
Any help is welcome.
Thanks,
Benoit
Benoit is offline   Reply With Quote
Old   November 5, 2009, 06:13
Anonymous
madad2005 is on a distinguished road
Can you post which settings you used per line on the graph?
madad2005 is offline   Reply With Quote
Old   November 5, 2009, 07:51
Benoit Bonnal
Sure, here are the relaxation factors i used:
green:
p: 0.4
U: 0.8
nuTilda: 0.8
Black:
p: 0.3
U: 0.7
nuTilda: 0.7
Blue:
p: 0.2
U: 0.5
nuTilda: 0.5
Red:
p: 0.1
U: 0.2
nuTilda: 0.2
Do you need anything else ?
Old   November 6, 2009, 22:42
Alberto Passalacqua
green:
p: 0.4
U: 0.8
nuTilda: 0.8
Black:
p: 0.3
U: 0.7
nuTilda: 0.7
Blue:
p: 0.2
U: 0.5
nuTilda: 0.5
Red:
p: 0.1
U: 0.2
nuTilda: 0.2
Two suggested experiments:
  • What happens using a relaxation factor bigger for p than for U. Say 0.6 for p, 0.4 for U?
  • Can you obtain a converged solution without under-relaxing?
Best,
Alberto Passalacqua
Relaxation and convergence sammi Phoenics 0 March 20, 2008 03:32
Relaxation Factors Tim Phoenics 3 June 30, 2004 02:03
relaxation parameter rvndr Main CFD Forum 0 May 5, 2004 12:34
Question on adjusting relaxation factor CFD Rookie Main CFD Forum 3 January 26, 2004 14:37
Relaxation factor Moon Siemens 1 June 13, 2003 11:13
