nonuniform boundary condition( U=f(y) ) ?
Old   November 5, 2009, 05:47
Default nonuniform boundary condition( U=f(y) ) ?
Jiang
panda60 is on a distinguished road
Dear Foamers:
I want to use nonuniform boundary condition in flow inlet. the velocity is changing with height. That is U=f(y). How can I add this condition to inflow boundary condition ?
Thank you very much.
panda60 is offline   Reply With Quote
Old   November 5, 2009, 09:48
Ulrich Heck
ulli is on a distinguished road
Hi Jiang
you can either look at the HotRoom example in the heatTransfer/buoyant* example. Here there is initial temperature field generated on a patch. Look at the setHotRoom.C-File and it will be quite clear how to do something similar for U.
Or take a look a the wiki:
http://openfoamwiki.net/index.php/Main_ContribOther
Here you find funkySetFields and groovyBC which also should solve your problem.
Ulrich
ulli is offline   Reply With Quote
Old   November 5, 2009, 12:28
ICL
Ali Sh
ICL is on a distinguished road
Here is the sample of boundary condition where your wall moving and you create a file (here called time-series) and add the speed for each time instant:
movingWall
type timeVaryingUniformFixedValue;
fileName "$FOAM_CASE/time-series";
outOfBounds clamp;
The format for time-series is:
(0.001 (Ux Uy Uz))
(0.0011 (0.0100075 0 0))
(0.0012 (0.0100089 0 0))
(0.0013 (0.0100105 0 0))
(0.0014 (0.0100121 0 0))
ICL is offline   Reply With Quote
Axis Boundary Condition..what is it? CFDtoy FLUENT 6 February 13, 2007 05:51
How to set boundary condition in Fluent for the fo Peiyong FLUENT 1 November 10, 2006 11:44
pressure boundary condition in fractional step Jean-François Corbett Main CFD Forum 3 January 10, 2006 08:49
1 and 2 Order Boundary condition at the same place CFD_Flo Main CFD Forum 4 July 11, 2005 11:57
How to resolve boundary condition problem? sam FLUENT 2 July 20, 2003 02:19
