low reynolds k omega / wall functions
Old   November 25, 2009, 07:20
Default low reynolds k omega / wall functions
stawrogin is on a distinguished road
I make my first steps with low-Reynolds models for heat transfer analysis.
When I understand the new wall function approach in OF 1.6. correctly, I “simply” can switch off the wall functions e.g. by using “calculated” in the nut-file and some reasonable bcs for omega and k at the walls. I build some test cases with grids of y+ below “1” and used fixed values for k (I used very low non-zero values) and zero gradient for omega. Does this make sense? But the convergence is quite poor and the results (e.g. when I estimate wallShear stresses from different models) differ strongly. Any hints or recommendations?
I also read that Fluent uses a low Reynolds correction for the k-omega model. Did anybody implement something like this in OF or compared the effect?
Thanks in advance
Stawrogin
stawrogin is offline   Reply With Quote
Old   March 30, 2011, 06:04
Anne Gerdes
Anne Lincke is on a distinguished road
Hey Stawrogin,
" fixed values for k (I used very low non-zero values) and zero gradient for omega. Does this make sense?"
Fixed values for k which are non-zero but low are good but zero gradient for omega does not make sense.
Have a look at the post
http://www.cfd-online.com/Forums/ope...tml#post296705
Anne Lincke is offline   Reply With Quote
Low Reynolds Number Instability in icoFoam - Cavity Case kmooney OpenFOAM Running, Solving & CFD 2 October 8, 2009 14:09
"OF uses logarithmic wall functions always" - does it changed in 1.6? yuhai OpenFOAM Running, Solving & CFD 2 September 17, 2009 12:16
LES with wall functions, wall boundary, Re 10000 subba CFX 4 July 10, 2007 05:04
Wall functions Confused Main CFD Forum 1 August 14, 1998 09:31
Wall functions or low-Re models? J. P. Main CFD Forum 7 July 9, 1998 11:11
