ggi
Old   November 26, 2009, 07:18
Default ggi
Andrea Pasquali
andrea.pasquali is on a distinguished road
I generated a model of a rotating cylinder.
I used the example in icoDyMFoam/mixerGgi in OpenFOAM1.5-dev.
I attached one image of the model (ggi.jpeg).
There is: the rotating patch "cilindro", the fixed patch "wall" and the patches "insideSlider" and "outsideSlider".
When I try to run icoDyMFoam, I obtain:
This mesh contains patches of type empty but is not 1D or 2D
by virtue of the fact that the number of faces of this
empty patch is not divisible by the number of cells.
Could anyone explain this error? The empty patches are on front and back of the model. What "the number of faces of this empty patch is not divisible by the number of cells" means?
Thanks in advance for any reply
Andrea
andrea.pasquali is offline   Reply With Quote
Old   November 27, 2009, 03:23
lord_kossity's Avatar
Andreas Dietz
lord_kossity is on a distinguished road
Hello Andrea,
it seems like you declared your defaultFaces to be of boundary type "empty" (look in your constant/polyMesh/boundary file). If this assumption is correct change "empty" in that file to the proper boundary type (e.g. "patch", "wall", ...) . When you did that, change your initial conditions in 0/ and the Error Messgae from above won't appear.
Best,
Andreas
lord_kossity is offline   Reply With Quote
Old   November 27, 2009, 04:54
Andrea Pasquali
Thank you very muck Andreas,
I understood my error! Now it's running
Best regards
Andrea
Andrea Pasquali
Difference between ggi and overlapGgi? GGI Tips and Tricks? philippose OpenFOAM Running, Solving & CFD 7 January 16, 2013 09:40
Performance of GGI case in parallel hannes OpenFOAM Running, Solving & CFD 26 August 3, 2011 03:07
GGI in OpenFOAM hjasak OpenFOAM Running, Solving & CFD 59 April 30, 2010 08:30
CFX GGI Interface Error (non-overlapping) surge519 CFX 1 August 3, 2009 18:54
GGI ERCOFTAC and general questions david OpenFOAM Running, Solving & CFD 8 August 25, 2008 09:22
