January 7, 2010, 12:33 |
grid analysis
hi guys,
i have a question about grids for open foam. i have created grids which are represented both in polymesh and in vtk format. the grids are properly constructed as the openfoam simulation works fine and the residuals converge. the thing i want is to analyze my grids. to be more precisly, i want to gain information about the maximum/minimum/average angles, edge lengths, edge length ratio etc. is there a simple way to solve this problem? i would prefer a solution which works also on windows (as paraview does), since i havent installed linux on my notebook so far. thank you very much for your help! best regards |
January 9, 2010, 16:22 |
Hrvoje Jasak
Rep Power: 33 |
Simply run the checkMesh utility - it will tell you all you need to know.
Enjoy, Hrv
January 10, 2010, 03:53 |
#3 | |
It is nice to use for small problems/learning and you just need a notebook capable booting from usb. read more about OF on Slax here http://www.cfd-online.com/Forums/ope...lax-based.html greetings elvis |
Grid sensitivity analysis | darookie | CFX | 2 | August 25, 2009 09:00 |
Combustion Convergence problems | Art Stretton | Phoenics | 5 | April 2, 2002 05:59 |
Stability Analysis of Rectilinear Grid | Zi-Wei Chiou | Main CFD Forum | 0 | December 7, 2001 00:33 |
Troubles modelling flow through a grid | Hans Klaufus | CFX | 1 | June 28, 2000 16:43 |
Stability analysis on a non-uniform grid | PRAVEEN CHANDRASHEKAR | Main CFD Forum | 7 | July 2, 1999 01:46 |
