[Commercial meshers] fluent3DMeshTo Foam/fluentMeshTo Foam
Old   January 18, 2010, 09:01
Default fluent3DMeshTo Foam/fluentMeshTo Foam
Arina
Akuji is on a distinguished road
Send a message via ICQ to Akuji
I've a mesh from fluent, and I must to visualisate in FOAM. But when I try to transfer .msh for OpenFOAM I haven't a result. When I use fluentMeshToFoam I haven't a file in constant/polyMesh/blockMeshDict.
When I use fluent3D I have errors:
FOAM Warning :
From function boundBox::boundBox(const pointField& points)
in file meshes/boundBox/boundBox.C at line 52
Cannot find bounding box for zero sized pointField, returning zero
Creating cellZone 0 name: kuzov type: solid
Creating cellZone 1 name: dym_gas type: fluid
#0 Foam::error:rintStack(Foam::Ostream&) in "/opt/OpenFOAM/OpenFOAM-1.5/lib/linux64GccDPOpt/libOpenFOAM.so"
#1 Foam::sigSegv::sigSegvHandler(int) in "/opt/OpenFOAM/OpenFOAM-1.5/lib/linux64GccDPOpt/libOpenFOAM.so"
#2 ?? in "/lib/libc.so.6"
#3 FoamlyTopoChange::getFaceOrder(int, Foam::List<int> const&, Foam::List<int> const&, Foam::List<int>&, Foam::List<int>&, Foam::List<int>&) const in "/opt/OpenFOAM/OpenFOAM-1.5/lib/linux64GccDPOpt/libdynamicMesh.so"
#4 FoamlyTopoChange::compact(bool, bool, int&, Foam::List<int>&, Foam::List<int>&) in "/opt/OpenFOAM/OpenFOAM-1.5/lib/linux64GccDPOpt/libdynamicMesh.so"
#5 FoamlyTopoChange::compactAndReorder(Foam:olyMe sh const&, bool, bool, bool, int&, Foam::Field<Foam::Vector<double> >&, Foam::List<int>&, Foam::List<int>&, Foam::List<Foam:bjectMap>&, Foam::List<Foam:bjectMap>&, Foam::List<Foam:bjectMap>&, Foam::List<Foam:bjectMap>&, Foam::List<Foam:bjectMap>&, Foam::List<Foam:bjectMap>&, Foam::List<Foam:bjectMap>&, Foam::List<Foam:bjectMap>&, Foam::List<Foam::Map<int> >&, Foam::List<int>&, Foam::List<int>&, Foam::List<Foam::Map<int> >&) in "/opt/OpenFOAM/OpenFOAM-1.5/lib/linux64GccDPOpt/libdynamicMesh.so"
#6 Foam:olyTopoChange::changeMesh(Foam:olyMesh&, bool, bool, bool, bool) in "/opt/OpenFOAM/OpenFOAM-1.5/lib/linux64GccDPOpt/libdynamicMesh.so"
#7 main in "/opt/OpenFOAM/OpenFOAM-1.5/applications/bin/linux64GccDPOpt/fluent3DMeshToFoam"
#8 __libc_start_main in "/lib/libc.so.6"
#9 __gxx_personality_v0 in "/opt/OpenFOAM/OpenFOAM-1.5/applications/bin/linux64GccDPOpt/fluent3DMeshToFoam"
Segmentation fault
What did I do incorrectly?
Akuji is offline   Reply With Quote
error with reactingFoam BakedAlmonds OpenFOAM Running, Solving & CFD 4 June 22, 2016 02:21
[blockMesh] error message with modeling a cube with a hold at the center hsingtzu OpenFOAM Meshing & Mesh Conversion 2 March 14, 2012 09:56
[blockMesh] BlockMesh FOAM warning gaottino OpenFOAM Meshing & Mesh Conversion 7 July 19, 2010 14:11
[blockMesh] Axisymmetrical mesh Rasmus Gjesing (Gjesing) OpenFOAM Meshing & Mesh Conversion 10 April 2, 2007 14:00
[Gmsh] Import gmsh msh to Foam adorean OpenFOAM Meshing & Mesh Conversion 24 April 27, 2005 08:19
