February 4, 2010, 07:46 |
problem with constant wall heat flux
hi foamers
i want to use a fixed heat flux boundary condition in a conjugate heat transfer problem i use fixedGradient boundary condition on T ; bottom { type fixedGradient; gradient uniform 10.417; } i know that heatflux = thermal conductivity (k) * tempreature gradient (dT/dN) so for k=12 , heatflux=125 w/m2 >> gradient=heatflux/k=10.417 please help me ,, is that right to describe my constant heat flux (125 w/m2) in OpenFOAM .. thank you very much .. |
February 4, 2010, 09:46 |
Stefan Herbert
this is the right way. Go on like this. Regards Stefan |
June 23, 2014, 14:23 |
Ian Dizon
Rep Power: 12 |
hello, i am trying to set up something similar where i have a constant heat flux.
in my case i have lamps heating up air in a room. my question is: would k be a property of the air? or of the lamp |
June 24, 2014, 03:07 |
Bárbara Arizmendi
Rep Power: 12 |
It depends on where you are fixing the heat flux. If you have simulated the lamp then you use the conductivity of the lamp. If you haven't simulated the lamp then you have to calculate the convective heat transfer coefficient (hc) or you can fix a HeatFlux boundary condition.
July 16, 2014, 08:30 |
multiregion solid conduction
Anastasios
Hi
I am also trying to do something similar and the option to fix the Gradient of T works fine but only if you have solids with the same k (thermal conductivity). If there are different domains with different k's the results are not as expected comparing with COMSOL or FLUENT applying the actual heat flux boundary value. Has anyone dealt with something like this in ChtMultiRegionFoam if yes any advice would be really helpful!!! Thanks in advance T. |
August 15, 2016, 16:20 |
heat flux setting
alaa
Hi
I have case that their is constant heat flux from ground and i put it 500 w/m2 but their is a problem that it is not effect the density of the air or it's velocity during solving and after calculation please help |
January 13, 2019, 08:18 |
Jianrui Zeng
Rep Power: 7 |
If I use fixedGradient BC for constant heat flux, should thermo conductivity be constant? if it is changing with T, how should I get constant heat flux? Thank you.
Sign of Heat Flux at wall | Kyung | FLUENT | 2 | February 26, 2016 16:25 |
Constant heat flux with uniform temperature | Jake Lee | FLUENT | 2 | April 13, 2011 22:08 |
Heat flux and k-e wall boundary conditions | Blob | CFX | 4 | June 8, 2009 05:10 |
wall heat flux | Sangeeta | FLUENT | 0 | May 7, 2009 02:22 |
Multicomponent fluid | Andrea | CFX | 2 | October 11, 2004 05:12 |
