John Deas
Rep Power: 17 ![]() |
I am running a simulation and I absolutely need it to run for 8000 iterations before writing fields to the disk and stopping. However, it always run for a different amount of iterations, 2099, 1884, 1853 ... My controlDict file is: Code:
startFrom latestTime; // stopAt endTime; stopAt nextWrite; // stopAt writeNow; endTime 875; deltaT 0.01; writeControl timeStep; writeInterval 8000; purgeWrite 0; writeFormat ascii; writePrecision 6; writeCompression compressed; timeFormat general; timePrecision 6; runTimeModifiable yes; |
John Deas
Found the error. I moved the time directories around, therefore the time index did not correspond with the directories number., and all worked logically when the time indexes were considered.
actuator disk | Atit | CFX | 9 | July 26, 2016 09:39 |
Modelling an actuator disk in FLUENT | teymourj | Main CFD Forum | 0 | April 28, 2009 21:42 |
rotating disk | David | FLUENT | 5 | August 16, 2006 06:07 |
Fatal error error writing to tmp No space left on device | maka | OpenFOAM Installation | 2 | April 3, 2006 08:48 |
CFD of tilting disk check valve | Greg Anderson | Main CFD Forum | 1 | July 13, 1999 17:07 |
