March 25, 2010, 11:52 |
buoyantBoussinesqPisoFoam Questions
Matthew J. Churchfield
Rep Power: 18 |
To whomever can answer,
I have two questions about buoyantBoussinesqPisoFoam. 1). Why is pEqn.setReference(pRefCell,pRefValue) not called after setting up the pressure equation? If you take a look at pisoFoam, the pressure referencing is done, but why isn't it done in buoyantBoussinesqPisoFoam? 2). Why is the temperature equation solved before the PISO loop. Currently, the T equation is solved right after the velocity predictor step. The predicted velocity is not divergence-free, and the T equation uses this incorrect velocity in its convection term. Wouldn't it be more appropriate to solve for T after the PISO loop with a good divergence-free velocity? I guess that would mean that velocity and pressure are solved with a time lagged T. Thanks, Matt |
[Other] Some perhaps stupid questions about calculix | lynx | OpenFOAM Meshing & Mesh Conversion | 11 | May 17, 2010 06:48 |
So many questions in DPM & UDF - Help! URGENT! | Prashanth | FLUENT | 0 | March 3, 2009 22:26 |
Fluent FAQ Started - Fill it With Questions | Jonas Larsson | FLUENT | 0 | September 12, 2005 10:41 |
Few questions | phi | FLUENT | 0 | March 4, 2005 09:23 |
turbulence modeling questions | llowen | Main CFD Forum | 3 | September 11, 1998 04:24 |
