Installation of Paraview
Old   March 26, 2010, 05:43
Default Installation of Paraview
Aloex is on a distinguished road
I have successfullly installed OF 1.6 on my system (ubuntu 9.10) with the help from this forum. Now I want to install paraview and get some problems.
What I done:
1. sudo apt-get install qt4-qmake
2. sudo apt-get install libqt4-dev
3. the steps from the README-File:
  • cd $WM_THIRD_PARTY_DIR
  • rm -rf paraview-3.6.1/platforms
  • makeParaView
After I tipped "makeParaView" I get the follow mistake:
"makeParaView: command not found"
I don't know what I have to do now. I'm new in Linux and OF.
I hope somebody of you can me help.
Regards Aloex
Aloex is offline   Reply With Quote
Old   March 26, 2010, 08:03
Johan Spång
josp is on a distinguished road
add ./ in front of the script i.e: ./makeParaView
josp is offline   Reply With Quote
Old   March 26, 2010, 11:03
Thank you very much. Paraview is running now!
What's the meaning of this "./"?
Old   March 26, 2010, 15:41
kippo is on a distinguished road
http://hvirvel.dk/wp/?p=3
Here are some usefull installation scripts
kippo
kippo is offline   Reply With Quote
Old   March 26, 2010, 17:18
Retired Super Moderator
Bruno Santos
The dot states that you're refering to the present/current folder. And in Linux, although when listing the makeParaView file, both represent the same file; but when executing a program, that program has to either belong to one of the folders listed in the PATH environment variable, or be given the correct folder path to that application.
One way to override this behaviour, is to add the dot symbol to that very same PATH... and that is exactly what the OpenFOAM makers have done, and that's why their steps are ambiguous Namely, they refer to either methods, because they both work in their system.
kippo
Those scripts actually don't build Paraview, they just make use of the prebuilt version that comes with ThirdParty binary packages... at least last time I checked. And rebuilding Paraview are sometimes necessary, due to graphic card drivers and other installed libraries that conflict with the prebuilt version.
Old   March 27, 2010, 06:37
Mark Olesen
olesen has a spectacular aura aboutolesen has a spectacular aura about
Adding '.' to the PATH may be convenient, but is generally not recommended for a secure system. It's probably just matter of habit though whether to write the shell command with or without a leading './' in documentation (with './' is better - less ambiguous).
olesen is offline   Reply With Quote
Old   March 27, 2010, 15:07
Taht's right, but if using Ubuntu all the small changes needed to get a useful ParaView / paraFoam are included then...
If got all the new things, then just go to the Third-party folder and then run ./makeParaView
(takes a lot of time...)
Old   March 28, 2010, 05:25
Thx for your replies.
This forum works really well.
Old   March 28, 2010, 07:49
Another additional info: If you run you OS in a different language than english (for me german): You have to add in the file:
$/HOME/OpenFoam/OpenFoam-1.6/bin/paraFoam (be aware, if version is different)
just the additional line in front of all other commands:
export LC_ALL=C
I am a newby, too. It cost a lot of time to get it run...
kippo
ps: I also recommend pyfoam
Gschaider et al. did a very good job
paraview installation woes vex OpenFOAM Installation 15 January 30, 2011 07:11
paraFoam reader for OpenFOAM 1.6 smart OpenFOAM Installation 13 November 16, 2009 21:41
64bitrhel5 OF installation instructions mirko OpenFOAM Installation 2 August 12, 2008 18:07
Paraview installation troubles jjhall OpenFOAM Installation 3 April 17, 2008 12:59
Paraview installation problem please help bender OpenFOAM Installation 2 February 27, 2006 05:00
