Set liquid level in a Tank
Old   April 4, 2010, 21:35
Default Set liquid level in a Tank
Benjamin
chemeng is on a distinguished road
Hello! I want to simulate a two phase mixing tank (air-water). I want to set the water level at a high of 0.26 meters in the y direction in the tank before the operation starts.
My overall domain is: (-0.129986 0 -0.129999) (0.13 0.35 0.129999)
I want to simulate two cases:
1. Without airation, using MRFSimpleFoam.
2. With airation, using MRFTwoPhaseEulerFoam.
For the first case I don't know how to set the liquid level.
For the second case I have tried setFields, but I don't know if it is correct. My setFieldsDict is:
regions
boxToCell
box (-0.129986 0 -0.12.9999) (0.13 0.26 0.12999);
fieldValues
volScalarFieldValue alpha 0
Could anybody help me to set the liquid level in the first case and say to me if in the second case the configuration is ok?
Thanks in advance.
chemeng is offline   Reply With Quote
Old   April 6, 2010, 04:07
ngj
Niels Gjoel Jacobsen
ngj will become famous soon enoughngj will become famous soon enough
The alpha value should be set to 1 not 0.
Best regards,
Niels
ngj is offline   Reply With Quote
Old   April 6, 2010, 10:52
Piotr Prusinski
piprus is on a distinguished road
Try something like this:
defaultFieldValues (
      volScalarFieldValue alpha1 0 // default value for the domain
  regions
      boxToCell
    fieldValues
      volScalarFieldValue alpha1 1 // value for the specified region
piprus is offline   Reply With Quote
Old   April 6, 2010, 19:39
Benjamin
But alpha is the dispersed phase volume fraction right? so if i put alpha equal to 1 it is like if my tank is fill with air, not with water I think. I am confused. Correct me if I am wrong. Thank you for your reply.
Old   April 6, 2010, 23:46
Alberto Passalacqua
MRFSimpleFoam is a single-phase solver, so you cannot specify the level of the liquid, since there is only one phase.
I assume MRFTwoPhaseEulerFoam is your extension of twoPhaseEulerFoam, since I've not seen a solver with that name :-)
However you are correct: alphas is the volume fraction of the dispersed phase.
As suggested above, setFields should work to set alpha. Take a look at the examples for twoPhaseEulerFoam.
Best,
Alberto Passalacqua
level, liquid, tank
Dynamic sloshing and hydrodynamic modeling of liquid storage tank for earthquake K i M Main CFD Forum 14 April 22, 2011 22:24
calculating Normal vector in level set method amir2920 Main CFD Forum 1 July 21, 2009 07:25
using level set method rubby Main CFD Forum 2 March 7, 2009 02:02
liquid level in a vertical pipe gorman FLUENT 2 November 22, 2001 11:44
Level Set in Cavitation Modeling Niklas Wikstrom Main CFD Forum 1 September 9, 1999 13:08
