Getting nu at a particular location, please help!
Old   May 31, 2013, 08:44
Default Getting nu at a particular location, please help!
Jack
JackW is on a distinguished road
Hi there!
I have the task of compiling some models into later versions of openFoam (from 1.7.1), I believe I am almost there however I have come a bit unstuck on:
nu()[CellI]
in the below code. Is there still a way to use index notation with nu in OF-2.1.0?
Thanks for any help you can give me!
Jack
labelHashSet fixCells;
scalarField yPlus = 0.547723*y_*sqrt(k_)/nu();
forAll(omega_, i)
	if(yPlus[i] < 2.0)
		fixCells.insert(i);
		setO[i]=1;
labelList fixCellsLabel = fixCells.toc();
scalarField fixO(fixCells.size());
forAll(fixO, i)
	label cellI =  fixCellsLabel[i];
	fixO[i]=6.0/beta1_.value()*nu()[cellI]/(sqr(y_[cellI]));
omegaEqn().setValues(fixCellsLabel, fixO );
JackW is offline   Reply With Quote
Old   May 31, 2013, 09:44
Bernhard
Bernhard is on a distinguished road
I don't think these kind of addressing really changed from 1.7 to 2.1. I assume you got problems with compiling, can you shows some error messages?
Bernhard is offline   Reply With Quote
Old   May 31, 2013, 09:56
Jack
Hi, thank you very much for a quick reply.
The error is as follows:
Making dependency list for source file v2fEASMkOmegaV2/v2fEASMkOmegaV2.C
In file included from v2fEASMkOmegaV2/v2fEASMkOmegaV2.C:670:0:
v2fEASMkOmegaV2/omegaBSLWall.H: In member function 'virtual void Foam::incompressible::RASModels::v2fEASMkOmegaV2::correct()':
v2fEASMkOmegaV2/omegaBSLWall.H:75:38: error: no match for 'operator[]' in 'Foam::incompressible::turbulenceModel::nu() const()[faceCelli]'
In file included from v2fEASMkOmegaV2/v2fEASMkOmegaV2.C:672:0:
v2fEASMkOmegaV2/setOmega.H:30:39: error: no match for 'operator[]' in 'Foam::incompressible::turbulenceModel::nu() const()[cellI]'
make: *** [Make/darwinIntel64Gcc46DPOpt/v2fEASMkOmegaV2.o] Error 1
Basically from my limited C++ knowledge I assumed this was down to the operator [] not existing anymore, so I assumed there was another way?
Thanks
Jack
Radiation interface hinca CFX 15 January 26, 2014 17:11
An error has occurred in cfx5solve: volo87 CFX 5 June 14, 2013 17:44
Error finding variable "THERMX" sunilpatil CFX 8 April 26, 2013 07:00
Errors running allwmake in OpenFOAM141dev with WM_COMPILE_OPTION%3ddebug unoder OpenFOAM Installation 11 January 30, 2008 20:30
