Forces in compressible internal flow
Old   April 22, 2010, 07:06
Default Forces in compressible internal flow
sasha
zabar is on a distinguished road
Hi all,
I tried calculate forces that act on cylinder inside a pipe. when i used simplefoam ,i get very good result. but when i switch to rhoporoussimplefoam (with zero porosity - i use it as a template for steady state compressible flow - air) i get wrong direction and component of force greater x150 .
for finding force i used :
functions
forces
type forces;
functionObjectLibs ("libforces.so"); //Lib to load
patches (buhna); // change to your patch name
rhoInf 1.24; //Reference density for fluid
CofR (0 0 0); //Origin for moment calculations
Is there anyone who can explain how do it right.
thanks in advance
Sasha
zabar is offline   Reply With Quote
Old   April 24, 2010, 17:58
sasha
hi all,
anyone have expirience
with force Utility for use it for Compressible Flow Fields ?
i tried look at forum but nothing.
please help, becouse i have very strange result ,and i don't understand where is problem
thank you
p.s.
i tried also with rhoSimpleFoam, and with rhoTurbFoam and i get similar result as in rhoporoussimplefoam.I work in O.F. 1.5 and geometry from SALOME. If there some indication that problem in mesh? i read that yplus in turbulent flow must be 30<y+<100, in my case average of y+ on cylinder is 1 (flow is turbulent, RE>20000).
wait for your suggestion .
thank in advance
Sasha
Old   April 26, 2010, 03:54
sasha
i tried refine the mesh - the same result.
what i should to do
Old   April 26, 2010, 10:13
Carlos Xisto
xisto is on a distinguished road
Send a message via MSN to xisto
I' sorry,
But I never need to calculate forces.
What is the turbulence model that you are using? Do you use wall functions?
Because if you do the y+ around 30 and 100 should work fine, but if you don't use wall functions you need a low-Re turbulence model that can solve the boundary layer.
Hope it helps,
CX
xisto is offline   Reply With Quote
Old   April 26, 2010, 10:44
sasha
Hi Carlos,
thank you for your answer,
i use k-e model, and not used wall function
1.where i can specify them? and what the rule?
2.which low-Re model you can suggest, and what's Re limitation for this model.
3.i read that y+ must be between 30 and 100 for fully turbulent flow- is right?
4.if your suggestion valid both for compressible and incompressible flow ?
thank you very much
Sasha.
Old   April 26, 2010, 10:59
Carlos Xisto
I never used a turbulence model in Foam, my experience is with FLUENT.
All high-Re RANS turbulence models include wall-functions because it is inappropriate to use them without. The rule is that for use wall functions you need a valid y+ between 30 and 100 (300 in Fluent).
If you want to use a low-Re you need a y+<=1. I could suggest Spalart-Allmaras, k-w or k-w SST.
Yes I think you are right, but If you want such y+ you need to coarse your mesh, in FLUENT is mandatory to use wall functions I think that in foam is also a need.
Old   April 26, 2010, 11:21
sasha
hi,
i found them in RASproperties file
i will try another RAS model,maybe it will help
thank you for your help.
sasha
Incompressible and compressible flow. Confused student. Main CFD Forum 27 March 18, 2017 12:25
Boundary Conditions for Internal compressible Flow xisto OpenFOAM Pre-Processing 26 May 17, 2016 02:30
About compressible flow at low mach hit Main CFD Forum 2 October 26, 2009 21:21
urgent help needed with 2d compressible flow James FLUENT 2 June 20, 2007 04:22
compressible channel flow.. R.D.Prabhu Main CFD Forum 0 July 17, 1998 17:23
