dieselEngineFoamLayer problems with spray
Old   March 19, 2010, 13:02
Default dieselEngineFoamLayer problems with spray
Peter_600 is on a distinguished road
Hi.
I try simulate the compresson stroke of an engine.
I am using 1.5-dev with a modified solver of dieselEngineFoam.
The modified solver is able to add and remove cells.
So far the movement of the piston with the topological changes didnt make troubble but when I want to inject fuel (for instance C7H16), it seems that the injected fuel doesn t influence the velocity and pressure field. The spray can be visualted with paraview (VTK).
The residuals of C7H16 doesn t change for any reason. Furthermore the added gas mass becomes negative.
When I try to run that case with dieselEngineFoam, it works. I assume that something is going wrong with the added layers.
I appreciate any kind of hints. Has someone experiences with that kind of approaches?
By interest I will upload a test case and the modified solver for adding and removing layers.
Peter
Peter_600 is offline   Reply With Quote
Old   March 22, 2010, 08:42
Problem solved.
I did a mistake in the YEqn.H file.
Just a line was missing
solve
fvm::ddt(rho, Yi)
+ mvConvection->fvmDiv(phi, Yi)
- fvm::laplacian(turbulence->muEff(), Yi)
dieselSpray.evaporationSource(i) <--- added
+ kappa*chemistry.RR(i),
mesh.solver("Yi")
regards
Old   May 7, 2010, 11:01
Default Spray
N. A.
N. A. is on a distinguished road
I understand that you added the source term to the equation. Were you able to add the spray source terms for both momentum and energy equation. Can you share how were you able to add all the spray source terms (mass, mometum and energy).
N. A. is offline   Reply With Quote
Problems with Spray Source Terms su_junwei OpenFOAM Running, Solving & CFD 8 May 10, 2009 07:54
Spray slows then stops coastal593 OpenFOAM Running, Solving & CFD 6 July 31, 2007 16:14
spray injection mmacrb FLUENT 0 January 10, 2007 04:57
problems with unsteady spray simulation Mathias FLUENT 1 July 20, 2006 16:13
DPM spray angle David FLUENT 0 December 8, 2003 05:45
