Problem about drag model in twoPhaseEulerFoam
Old   May 10, 2010, 09:57
Default Problem about drag model in twoPhaseEulerFoam
beauty
beauty is on a distinguished road
Hi, friends
I encountered some problems about the drag models in the twoPhaseEulerFoam solver.
1First one is about the calculation of particle Remolds number in drag models. For example, in sourcefile of WeYu.C, the code is as follows:
Foam::tmp<Foam::volScalarField> Foam::WenYu::K
const volScalarField& Ur
) const
volScalarField beta = max(scalar(1) - alpha_, scalar(1.0e-6));
volScalarField bp = pow(beta, -2.65);
volScalarField Re = max(Ur*phasea_.d()/phaseb_.nu(), scalar(1.0e-3));
volScalarField Cds = 24.0*(scalar(1) + 0.15*pow(Re, 0.687))/Re;
forAll(Re, celli)
if(Re[celli] > 1000.0)
Cds[celli] = 0.44;
return 0.75*Cds*phaseb_.rho()*Ur*bp/phasea_.d();
From the code, the particle Remolds number is calculated by Re=ρb|Ur|da/μb, and the Ur is defined via const volScalarField& Ur. But in theory, Remolds number is defined as Re=ρbUrda/μb. I am a rookie with C++, is the sentence const volScalarField& Ur equals to|Ur|?
2Second is the compile error when change the blue line to:
volScalarField Cds = 24.0*(scalar(1) + 0.15*pow(Re*beta, 0.687))/(Re*beta);
I attach my source file and the log of wmake.
Look forward to your advance.
Thanks!
beauty
beauty is offline   Reply With Quote
Old   May 11, 2010, 11:28
Laurence R. McGlashan
l_r_mcglashan will become famous soon enough
1) You have to send it the magnitude of the relative velocity. You can see this within the twoPhaseEulerFoam solver in liftDragCoeffs.H.
2) I'm not sure. Did you 'wmake libso' in interfacialModels?
Laurence R. McGlashan :: Website
l_r_mcglashan is offline   Reply With Quote
Old   May 12, 2010, 03:36
beauty
Hi
Thank you for your help. Yes, it is like you said I have to send the magnitude of the relative velocity, which is executed by liftDragCoeffs.H in twoPhaseEulerFoam. Miss the file (liftDragCoeffs.H) is my fault.
I didn’t “wmake libso” in interfacialModels. I just performed “wmake” in terminal. Is this the problem?
beauty
Old   May 12, 2010, 05:01
I assume that what you did was copy one of the dragModels and alter it slightly? You need to recreate the library libEulerianInterfacialModels. You'll see in the folder twoPhaseEulerFoam/interfacialModels there is a folder Make/ add your new model to Make/files, and then run 'wmake libso' from the folder twoPhaseEulerFoam/interfacialModel. You'll then be able to use your new drag model.
Old   May 12, 2010, 08:08
beauty
yes, you are right. I just copy one dragModel and alter it. Then I add my new model to Make/files, and run wmake.Today I compiled the dragmodel following your guidance, everything is ok. Thank you very much.
beauty
Old   May 13, 2010, 16:49
Default Regarding twoPhaseEulerFoam
M K Singh
mksingh is on a distinguished road
beauty
Hi
Regarding twoPhaseEulerFoam in OF1.6, I tried a simple 3-D bubble column, but never successful in getting right results. Some times I get very unstable free surface and after a certain point I see that whole domain is filled with continuous phase. Have you encountered the same problems with TwoPhaseEulerFoam?
With regards.
M K
mksingh is offline   Reply With Quote
Old   May 13, 2010, 20:13
Alberto Passalacqua
Why do you divide by beta?
I know it is "common practise" to see that around, but Wen & Yu drag does not contain alpha inside the Reynolds number. The correction due to the presence of more than one particles is made introducing the beta^{-2.65}, the rest stays the same as in the single-particle case.
Alberto Passalacqua
Old   May 13, 2010, 20:14
Alberto Passalacqua
Originally Posted by mksingh View Post
Hi
With regards.
M K
Usually this happens because your Courant number (time step) is too big.
Best,
Alberto Passalacqua
Old   May 14, 2010, 05:15
Default To M K
beauty
Hi
With regards.
M K
Hi
I didn't encounter the same problem. I am a rookie to openfoam, so I can't give you good solution, I feel so sorry. Maybe the reason is as Alberto said, your time step is too big. I have seen a paper about simulaiton of the gas-solid fluidized bed, in which the time step is set to 0.00001.
beauty
Old   May 14, 2010, 05:37
Default To Alberto
beauty
Hi, Alberto
After seeing your reply, I check my equation again. The WenYu drag Model I have read in paper is different from the expression in openfoam. I can't write formula here, so I attached a file. what is your opinion?
beauty
Old   May 14, 2010, 10:36
Alberto Passalacqua
they're both used. I checked again, and you find both of them reported as "Wen & Yu (1966)" model. I'll try to find the original paper from Wen & Yu (1966) to clarify.
Alberto Passalacqua
Old   May 14, 2010, 10:37
Alberto Passalacqua
Quite normal time step for dense fluidized beds. Usually 5 10^-4 - 10^-5, and even smaller if you introduce frictional models.
Best,
Alberto Passalacqua
Old   May 14, 2010, 23:11
Default happen to have the same view
  #13
beauty
Hi
It's happy to see that. I also have the idea to find the original paper. Please let me know what's the result.
beauty
Old   May 14, 2010, 23:20
Alberto Passalacqua
I didn't have time to go to the library and dig it out. In the meanwhile, the good review of
Enwald, Peirano and Amstedt, "Eulerian two-phase theory applied to fluidization", Int. J. Multiphase Flow, 1996
report that Wen & Yu used the Schiller and Naumann correlation for Cd, which does not contain alpha multiplying the Reynolds number.
Best,
Alberto Passalacqua
Use of k-epsilon and k-omega Models Jade M Main CFD Forum 40 January 27, 2023 07:18
Polyflow Simulation with ViscoElastic Model memory problem sid2909 ANSYS 0 May 10, 2010 05:27
multiphase mixing Problem with MRF model in MixSim Srinivas FLUENT 0 October 17, 2005 06:35
Converge problem of Mixture Model Jen FLUENT 8 August 17, 2005 18:23
Writing a BCDEFI problem for RSM model S. Bottenheim Siemens 2 January 28, 2005 08:55
