Boundary condition setting for non-premixed combustion using reactingFoam
Old   May 23, 2010, 22:55
Default Boundary condition setting for non-premixed combustion using reactingFoam
sylang Young
skyopener is on a distinguished road
Hello, Foamers,
I am new with OpenFOAM .
I am trying to simulating turbulent jet combustion from Sandia.gov..and I have some problems on the setting of boundary condition. After having been tried many settings, I am lost. So I hope someone can help me, any hints would be appreciated!
Following is the simulation condition.
It is non-premixed combustion. So I use the reactingFoam solver.
So k-epsilon model is used to the turbulent flow.
It has 2 inlets and 1 outlet, one inlet is for the fuel, the other for coflow..
inlet1: H2/N2, width--2.285mm,velocity--107m/s,T--305k
coflow: Air, radius--288mm,velocity--3.5m/s,T--1045k
It is a 2-D geometry, the top is the outlet, vertical is the surround, the lower has two inlets.
so the boundary condition was setted as follow initially:
>----p
internalField uniform 1e+5;
boundaryField
nozzle
type zeroGradient;
coflow
type zeroGradient;
out
type fixedValue;
value uniform 1e+5;
surround
type zeroGradient;
frontAndBack
type empty;
>------------U
internalField uniform (0 0 0);
boundaryField
nozzle
type fixedValue;
value uniform (0 107 0);
coflow
type fixedValue;
value uniform (0 3.5 0);
out
type inletOutlet;
inletValue uniform (0 0 0);
value uniform (0 0 0);
surround
// type fixedValue;
//value uniform (0 0 0);
type zeroGradient;
frontAndBack
type empty;
>----------------T
internalField uniform 1045;
boundaryField
nozzle
type fixedValue;
value uniform 305;
coflow
type fixedValue;
value uniform 1045;
out
//type fixedValue;
//value uniform 800;
type zeroGradient;
surround
//type fixedValue;
type zeroGradient;
frontAndBack
type empty;
>--------------N2
internalField uniform 0.745;
boundaryField
nozzle
type fixedValue;
value uniform 0.977;
coflow
type fixedValue;
value uniform 0.75;
out
type zeroGradient;
surround
type zeroGradient;
frontAndBack
type empty;
>------------------K
internalField uniform 1;
boundaryField
nozzle
type fixedValue;
value uniform 1;
out
type zeroGradient;
surround
type zeroGradient;
coflow
type fixedValue;
value uniform 1;
frontAndBack
type empty;
>-------------------------epsilon
internalField uniform 90;
boundaryField
nozzle
type fixedValue;
value uniform 90;
out
type zeroGradient;
surround
type zeroGradient;
coflow
type fixedValue;
value uniform 90;
frontAndBack
type empty;
These are the boundary condition settings
But the result is far away from the real world..
The problem must be focused on the boundary setting. Although many settings have been tried, the results are always terrible.
Could someone give me any hint?
Could some hearted person attach his similar cases setting or email it to me. The address is skyopener@sina.com
Great thanks to you.
Liang shi
skyopener is offline   Reply With Quote
Transient outlet boundary condition problem jwillie2000 CFX 1 December 7, 2009 17:07
RPM in Wind Turbine Pankaj CFX 9 November 23, 2009 04:05
Help for setting 3D boundary condition in compressing water vapor sogolf FLUENT 0 September 27, 2009 15:05
How to set boundary condition in Fluent for the fo Peiyong FLUENT 1 November 10, 2006 11:44
Problem setting boundary condition from file Antonis CFX 1 September 11, 2006 16:53
