May 30, 2010, 14:26 |
Very Very SLOW interFoam on Cluster
Ovie Doro
Rep Power: 16 |
Hi..
I am running some modified version of interFoam on a cluster. My parallel computation uses 40 processors and the problem has about 700k grid cells. The modified solver includes an energy eqution and uses the MULES Implicit solver for the alpha1 transport equation. The computation has been shockingly slow even though I am not writing out results at any time steps. The computation has been running for almost 24 hours with an average time step of 1e-4 and it is yet to compute 2 seconds of real time. Has anyone encoutered similar problems? Any ideas to fix this? Thanks |
May 31, 2010, 01:31 |
#2 | |
J. Cai
Rep Power: 17 |
Best regards, Chiven |
May 31, 2010, 03:50 |
Suresh kumar Kannan
Rep Power: 17 |
Hello ,
i also had the same experience while using a modified version of interFoam with MULES implicit, but i was not solving the energy equation in my case. Since you are using MULES implicit, i assume that you are using CrankNicholson as dt scheme for all the equations. Why dont you just try to run one case with backward or Euler timestep and see if the selection of time integration schemes is causing the problem . You can also try reducing the CrankNicholson coefficient to 0.9 and see the difference. regards K.Suresh kumar |
May 31, 2010, 04:06 |
#4 | |
Stefan Herbert
Rep Power: 17 |
I think your problem is much to small to use 40 processors. You are spending more time with communication than with solving. I'd suggest you start your case with only 4-8 processors and look, if you still don't get some speed-up. Regards, Stefan |
InterFoam stops after deltaT goes to 1e14 | francesco_b | OpenFOAM Running, Solving & CFD | 9 | July 25, 2020 06:36 |
How to install the OpenFoam in the cluster. Please help me! | flying | OpenFOAM Installation | 6 | November 27, 2009 03:00 |
Open Channel Flow using InterFoam type solver | sxhdhi | OpenFOAM Running, Solving & CFD | 3 | May 5, 2009 21:58 |
Linux Cluster Performance with a bi-processor PC | M. | FLUENT | 1 | April 22, 2005 09:25 |
To Jonas: Linux Cluster | Mark Render | Main CFD Forum | 1 | June 20, 2002 04:19 |
