Hassan Kassem
Rep Power: 18 ![]() |
Dear Foamers,
I am a new OpenFOAM user working on non-premixed combustion flames (diffusion flames). I was using Fluent ![]() Currently, I am searching for all available combustion models in OpenFOAM and I noticed the following;
The problem is the second point because it makes open source codes lose it's essence. That will make each new user or group decides to use OpenFOAM to build its own solvers and models which already done by others. I hope that these codes are shared somewhere and it was my fault to find it. Can anyone show me where can I find the combustion models codes especially for diffusion flames? and which models are never implemented in OpenFOAM before? Where are the active combustion groups? or should we make a one?! |
MSR CHANDRA MURTHY
Rep Power: 17 ![]() |
Wait for few days, in the upcoming 5th OpenFOAM workshop considerable advancement in combustion modelling is expeted.
http://web.student.chalmers.se/group...stractOFW5.pdf |
Hassan Kassem
Thank you
#4 | |
Alberto Passalacqua
Rep Power: 36 ![]() ![]() |
However I don't see a major problem in re-implementing the model. Sometime it is easier than understanding others code, if not written very cleanly and documented. And in these years I have learnt that "announcements" of new features and solvers by members of the community do not mean these features will be released by the authors, and, sometime, they don't mean they are actually ready. In other words, if you need a model, start coding, don't wait ![]()
Alberto Passalacqua GeekoCFD - A free distribution based on openSUSE 64 bit with CFD tools, including OpenFOAM. Available as in both physical and virtual formats (current status: http://albertopassalacqua.com/?p=1541) OpenQBMM - An open-source implementation of quadrature-based moment methods. To obtain more accurate answers, please specify the version of OpenFOAM you are using. ![]() |
Hassan Kassem
You are right. I should start coding what I need. What is your advice for a new foamer?
![]() What do you think, should we start a new combustion group? I did not find anyone also. ![]() |
Laurence R. McGlashan
Rep Power: 23 ![]() |
What exactly are you trying to model? If your chemistry is complex then you'll have to use flamelet methods. My group has a flamelet equation solver available on sourceforge which is written in C++, and I have used that to solve lagrangian style flamelets for a laminar diffusion flame successfully. Takes a long time to solve though... You're probably best off just writing it yourself to be honest, it didn't take that long.
Regarding point 2), have you actually contacted other research groups? In my experience they are often very willing to share code, you just have to ask nicely ![]()
Laurence R. McGlashan :: Website |
#7 | |
Alberto Passalacqua
My knowledge of combustion is purely theoretical and quite limited though, since I have never actually worked on it (my interest is elsewhere, aka multiphase flow), so I doubt my contribution could be of much use :-)
#8 | |
Hassan Kassem
I am new OpenFOAM user and I do not have experience yet about the working groups in this area ![]() What is the name of your group project in sourceforge? |
#9 |
http://sourceforge.net/projects/mopssuite/ is the site, you can svn clone the repository and the flamelet solver is called 'camflow'. It can use CVODE or RADAU5 which come with the repository. There are some examples you can run it on and also you can generate some partially completed documentation using doxygen.
#10 |
Also, if you want an overview of turbulent combustion, I like this book:
http://www.amazon.co.uk/INTRODUCTION.../dp/1860947794 Maybe I'm slightly biased because I went on the course, but it covers almost everything and you can take it as a starting point.
#11 | |
Hassan Kassem
Thank you ![]() |
#12 | |
Hassan Kassem
#13 |
Are you sure? What can you see? There should be trunk folders within each software directory, and they'll have include/ and source/ folders in them.
#14 |
Hassan Kassem
#15 |
Ah, this code is under development, so you have to get it from the svn repository:
svn co https://mopssuite.svn.sourceforge.net/svnroot/mopssuite mopssuite You can view the svn repository here: http://mopssuite.svn.sourceforge.net/viewvc/mopssuite/
#16 | |
Hassan Kassem
I downloaded it |
#17 |
Hassan Kassem
Dear All,
I need your advice. I am wondering, is it possible for a new OpenFOAM user to implement the flamelet model for turbulent non-premixed flames of hydrocarbons mixture fuels like (ch4/h2) alone (as a master student)? How long will it take? How complex is it? concerning that, I will try to follow the available codes as mush as possible, It will be my full time work and I need to have some output by next September. What do you think? ![]() |
Where to find the theory for weller flamet combustion model | 21kalee | OpenFOAM Running, Solving & CFD | 7 | December 19, 2012 17:18 |
can alternate combustion model by UDF? | Han Xingsi | FLUENT | 0 | September 1, 2008 02:08 |
To respected Henry weller and Foamers who use combustion in openfoam | 21kalee | OpenFOAM Running, Solving & CFD | 0 | December 29, 2007 07:36 |
Hydrogen Air combustion in a combustion chamber | popi | CFX | 7 | July 11, 2007 18:40 |
Need Similar Combustion Tutorial as my model | Arnab | Siemens | 0 | May 24, 2005 18:23 |
