chem_inp and chem_inp.15, DieselFoam
Old   June 29, 2010, 09:09
Default chem_inp and chem_inp.15, DieselFoam
Rickard
Rickard.Solsjo is on a distinguished road
I was reading the other threads but I still have some questions.
Are chem_inp and chem_inp15 subtitutes?
If I e.g. am using C12H26 the reaction is
C12H26+18.5O2 -> 12CO2 + 13H20...
Do I create the file
ELEMENTS
H O C N AR
END
SPECIE
C12H26O2 N2 CO2 H2O
END
REACTIONS
C12H26+18.5O2 -> 12CO2 + 13H20 5.00E+8 0.0 15780.0! 1
FORD / C12H26 0.25 /
FORD / O2 1.5 /
END
or something like this ? Under chem_inp 15 they have more reactions. Do I need these?
Rickard.Solsjo is offline   Reply With Quote
Old   July 5, 2010, 05:04
marcbest is on a distinguished road
i don't know the forwardreaction orders (FORD) for dodecane, you should look for a suitable reaction mechanism...
the chem.inp in tutorial aachen bomb is a global reacting mechanism. that means, that there are only reactants and productucts described.
the chem.inp_15 is a detailled reaction mechanism, where (all)many elementary reactions are described
the difference is that detailled mechanisms describe the case more precise, but as there are more species, more species-equations have to be solved, so the simulation takes longer
i think you should start with global mechanism, as you wrote in red, but maybe you have to check the arrhenius rates etc.
marcbest is offline   Reply With Quote
