The question about Fluent's mesh to OpenFOAM
Like Tree2Likes
  • 2 Post By swordw7
Old   December 3, 2017, 22:31
Default The question about Fluent's mesh to OpenFOAM
LiangJian
swordw7 is on a distinguished road
Dear All,
I want to transfer a Fluent's mesh to OpenFOAM, but I failed. I can not find the reason. I am a newer to OpenFOAM.
my mesh is here:
https://pan.baidu.com/s/1nvpBfDZ
swordw7 is offline   Reply With Quote
Old   December 3, 2017, 22:33
ali.ikhsanul's Avatar
Ali Ikhsanul Qauli
ali.ikhsanul is on a distinguished road
Send a message via Skype™ to ali.ikhsanul
You need to include the error message here, so that anyone can understand the problem you have.
__________________________
Implement what theory predict
Ali Ikhsanul Qauli
ali.ikhsanul is offline   Reply With Quote
Old   December 3, 2017, 23:23
LiangJian
enginelab@enginelab:~/Desktop/zhangjiawen$ fluentMeshToFoam meshfile.msh
| \\ / O peration | Version: 4.0 |
| \\ / A nd | Web: www.OpenFOAM.org |
| \\/ M anipulation | |
Build : 4.0
Exec : fluentMeshToFoam meshfile.msh
Date : Dec 04 2017
Time : 11:12:39
Host : "enginelab"
PID : 13061
Case : /home/enginelab/Desktop/zhangjiawen
nProcs : 1
allowSystemOperations : Allowing user-supplied system call operations
Create time
number of faces: 204249
Number of points: 2794
Reading uniform faces
Reading points
FINISHED LEXING
#0 Foam::error:rintStack(Foam::Ostream&) in "/home/enginelab/OpenFOAM/OpenFOAM-4.0/platforms/linux64GccDPInt64Opt/lib/libOpenFOAM.so"
#1 Foam::sigSegv::sigHandler(int) in "/home/enginelab/OpenFOAM/OpenFOAM-4.0/platforms/linux64GccDPInt64Opt/lib/libOpenFOAM.so"
#2 ? in "/lib/x86_64-linux-gnu/libc.so.6"
#3 ? in "/home/enginelab/OpenFOAM/OpenFOAM-4.0/platforms/linux64GccDPInt64Opt/bin/fluentMeshToFoam"
#4 __libc_start_main in "/lib/x86_64-linux-gnu/libc.so.6"
#5 ? in "/home/enginelab/OpenFOAM/OpenFOAM-4.0/platforms/linux64GccDPInt64Opt/bin/fluentMeshToFoam"
Segmentation fault
Old   December 3, 2017, 23:27
LiangJian
ok, thank you for you suggestion.
Old   December 4, 2017, 06:42
BlnPhoenix is on a distinguished road
Is your mesh 2D or 3D?
BlnPhoenix is offline   Reply With Quote
Old   December 4, 2017, 06:47
LiangJian
My mesh is 2D.
Old   December 4, 2017, 06:56
ASCII or binary mesh file?
Old   December 4, 2017, 07:20
LiangJian
Thank you for your reply. When I try export the my mesh as ASCII mesh.I was successful. Thank you for you hints.
hjasak and BlnPhoenix like this.
decomposePar problem: Cell 0contains face labels out of range vaina74 OpenFOAM Pre-Processing 37 July 20, 2020 05:38
OpenFOAM v3.0+ ?? SBusch OpenFOAM 22 December 26, 2016 14:24
small question about the functionalities of topological changes in OpenFoam ngj OpenFOAM Running, Solving & CFD 2 February 28, 2013 10:02
Converting Starccm+ mesh Ladnam OpenFOAM 0 September 14, 2011 06:30
ICEM 10 mesh question DAK565656 CFX 6 May 8, 2007 12:16
