Flow through an elbow, differences with starccm+
Old   October 28, 2010, 04:55
Default Flow through an elbow, differences with starccm+
RalphS is on a distinguished road
I simulate a flow through an elbow.
I compare my results with a simulation with starccm+.
I use the solver "my_rhoSimpleFoam", I have modified the enthalpy equation to get a right Temperature field.
Here some information of my results:
The velocity field is identical.
The static pressure field is also identical.
Kinetic energy and eddy-viscosity almost identical.
I also calculate an "Uniformity Index" at the outlet, the value is also comparably.
The distribution of the Temperaturfield is also very analog (With the new total enthalpy equation). But the temperatur is a bit too low, and the density a little bit too high at the outlet. So my total pressure loss (measuring, outlet - inlet) is about 50 % too low.
The value of total Temperatur is identical.
I think either the total enthalpy equation is not 100 % perfect, or I don't use the right thermophysical model. Have you some idea?
Regards
Ralph
RalphS is offline   Reply With Quote
Flow meter Design CD adapco Group Marketing Siemens 3 June 21, 2011 08:33
pressure distribution in water flow, differences in icoFoam and COMSOL deniggo OpenFOAM Running, Solving & CFD 14 September 30, 2010 03:48
Natural convection - Inlet boundary condition max91 CFX 1 July 29, 2008 20:28
reversed flow at velocity inlet / mass flow inlet ib FLUENT 1 March 26, 2007 13:11
transform navier-stokes eq. to euler-eq. pxyz Main CFD Forum 37 July 7, 2006 08:42
