November 26, 2010, 03:59 |
libcompressibleTurbulenceModel.so
Farshad
I am trying to compile reactingFoam and other combustion solvers in openfoam1.7.0 The following error is common in all these compilations: [farshad@farshad reactingFoam]$ wclean [farshad@farshad reactingFoam]$ wmake Making dependency list for source file reactingFoam.C SOURCE=reactingFoam.C ; g++ -m64 -Dlinux64 -DWM_DP -Wall -Wno-strict-aliasing -Wextra -Wno-unused-parameter -Wold-style-cast -Wnon-virtual-dtor -O3 -DNoRepository -ftemplate-depth-40 -I/home/farshad/OpenFOAM/OpenFOAM-1.7.0/src/turbulenceModels/compressible/turbulenceModel -I/home/farshad/OpenFOAM/OpenFOAM-1.7.0/src/thermophysicalModels/specie/lnInclude -I/home/farshad/OpenFOAM/OpenFOAM-1.7.0/src/thermophysicalModels/reactionThermo/lnInclude -I/home/farshad/OpenFOAM/OpenFOAM-1.7.0/src/thermophysicalModels/basic/lnInclude -I/home/farshad/OpenFOAM/OpenFOAM-1.7.0/src/thermophysicalModels/chemistryModel/lnInclude -I/home/farshad/OpenFOAM/OpenFOAM-1.7.0/src/ODE/lnInclude -I/home/farshad/OpenFOAM/OpenFOAM-1.7.0/src/finiteVolume/lnInclude -IlnInclude -I. -I/home/farshad/OpenFOAM/OpenFOAM-1.7.0/src/OpenFOAM/lnInclude -I/home/farshad/OpenFOAM/OpenFOAM-1.7.0/src/OSspecific/POSIX/lnInclude -fPIC -c $SOURCE -o Make/linux64GccDPOpt/reactingFoam.o g++ -m64 -Dlinux64 -DWM_DP -Wall -Wno-strict-aliasing -Wextra -Wno-unused-parameter -Wold-style-cast -Wnon-virtual-dtor -O3 -DNoRepository -ftemplate-depth-40 -I/home/farshad/OpenFOAM/OpenFOAM-1.7.0/src/turbulenceModels/compressible/turbulenceModel -I/home/farshad/OpenFOAM/OpenFOAM-1.7.0/src/thermophysicalModels/specie/lnInclude -I/home/farshad/OpenFOAM/OpenFOAM-1.7.0/src/thermophysicalModels/reactionThermo/lnInclude -I/home/farshad/OpenFOAM/OpenFOAM-1.7.0/src/thermophysicalModels/basic/lnInclude -I/home/farshad/OpenFOAM/OpenFOAM-1.7.0/src/thermophysicalModels/chemistryModel/lnInclude -I/home/farshad/OpenFOAM/OpenFOAM-1.7.0/src/ODE/lnInclude -I/home/farshad/OpenFOAM/OpenFOAM-1.7.0/src/finiteVolume/lnInclude -IlnInclude -I. -I/home/farshad/OpenFOAM/OpenFOAM-1.7.0/src/OpenFOAM/lnInclude -I/home/farshad/OpenFOAM/OpenFOAM-1.7.0/src/OSspecific/POSIX/lnInclude -fPIC Make/linux64GccDPOpt/reactingFoam.o -L/home/farshad/OpenFOAM/OpenFOAM-1.7.0/lib/linux64GccDPOpt \ -lcompressibleRASModels -lcompressibleLESModels -lreactionThermophysicalModels -lspecie -lbasicThermophysicalModels -lchemistryModel -lODE -lfiniteVolume -lOpenFOAM -liberty -ldl -lm -o /home/farshad/OpenFOAM/OpenFOAM-1.7.0/applications/bin/linux64GccDPOpt/reactingFoam /usr/bin/ld: Make/linux64GccDPOpt/reactingFoam.o: undefined reference to symbol 'Foam::compressible::turbulenceModel::New(Foam::Ge ometricField<double, Foam::fvPatchField, Foam::volMesh> const&, Foam::GeometricField<Foam::Vector<double>, Foam::fvPatchField, Foam::volMesh> const&, Foam::GeometricField<double, Foam::fvsPatchField, Foam::surfaceMesh> const&, Foam::basicThermo const&)' /usr/bin/ld: note: 'Foam::compressible::turbulenceModel::New(Foam::Ge ometricField<double, Foam::fvPatchField, Foam::volMesh> const&, Foam::GeometricField<Foam::Vector<double>, Foam::fvPatchField, Foam::volMesh> const&, Foam::GeometricField<double, Foam::fvsPatchField, Foam::surfaceMesh> const&, Foam::basicThermo const&)' is defined in DSO /home/farshad/OpenFOAM/OpenFOAM-1.7.0/lib/linux64GccDPOpt/libcompressibleTurbulenceModel.so so try adding it to the linker command line /home/farshad/OpenFOAM/OpenFOAM-1.7.0/lib/linux64GccDPOpt/libcompressibleTurbulenceModel.so: could not read symbols: Invalid operation collect2: ld returned 1 exit status make: *** [/home/farshad/OpenFOAM/OpenFOAM-1.7.0/applications/bin/linux64GccDPOpt/reactingFoam] Error 1 [farshad@farshad reactingFoam]$ .................................................. ......................................... please tell me where i can find a better source for compressibleturbulence library. Kind Regards, Farshad |
November 26, 2010, 06:30 |
Retired Super Moderator
Bruno Santos
Rep Power: 128 |
Greetings Farshad,
I saw your previous thread yesterday, but I postponed answering to you and eventually forgot to come back Anyway, my guess is that you're building OpenFOAM 1.7.0 in a Fedora 13 or 14, which is a very relevant information! And for Fedora, you better read this thread: http://www.cfd-online.com/Forums/ope...dora-13-a.html Best regards and good luck! Bruno
November 27, 2010, 14:20 |
except reactingFoam
Farshad
Dear Bruno,
Thanks for your nice help .Following your advice, i could compile all combustion solvers except reactingFoam and it gives me several errors such as: /home/farshad/OpenFOAM/OpenFOAM-1.7.1/src/turbulenceModels/compressible/turbulenceModel/turbulenceModel.H:153: error: expected ‘;’ before ‘&’ token /home/farshad/OpenFOAM/OpenFOAM-1.7.1/src/turbulenceModels/compressible/turbulenceModel/turbulenceModel.H:159: error: expected ‘;’ before ‘const’ /home/farshad/OpenFOAM/OpenFOAM-1.7.1/src/turbulenceModels/compressible/turbulenceModel/turbulenceModel.H:159: error: ISO C++ forbids declaration of ‘volVectorField’ with no type /home/farshad/OpenFOAM/OpenFOAM-1.7.1/src/turbulenceModels/compressible/turbulenceModel/turbulenceModel.H:159: error: expected ‘;’ before ‘&’ token Again i thank you for your kind help. Farshad |
November 28, 2010, 09:34 |
Bruno Santos
Rep Power: 128 |
Hi Farshad,
This is odd... there must have been some other error as well before that, something about a missing header file. Because those errors are indicative of missing header files that define "volScalarField" and "volVectorField". If you are using Fedora, it would be best to use OpenFOAM 1.7.x. Best regards, Bruno
