OpenFOAM-1.6-ext Installation QT
Old   December 1, 2010, 04:55
Default OpenFOAM-1.6-ext Installation QT
abminternet is on a distinguished road
I have been trying to install OpenFOAM 1.6-ext for a while now, and i have had no success with stage4 of the Thirdparty directory. At first I realized QT wasn't being installed so the whole thing just skipped. I modified the script because the line that installed QT was commented, so i uncommented it. Is there any reason why it should be commented? and if yes, then how should I install QT then?? with the uncommented line I get the following error:
/usr/bin/ld: warning: libQtCLucene.so.4, needed by /opt/software/openfoam/extend/OpenFOAM-1.6-ext/ThirdParty/rpmBuild/BUILD/qt-everywhere-opensource-
src-4.7.0/lib/libQtHelp.so, not found (try using -rpath or -rpath-link)
after that there is just a bunch of effor messages, related with QCLUCENE i guess, and then it ends saying it couldn't build the rpm.
Any suggestions? I would pretty much appreciate it
abminternet is offline   Reply With Quote
Old   December 1, 2010, 05:55
Hrvoje Jasak
hjasak will become famous soon enough
Yes, my fault - the compilation of qt takes forever and the nightly test loop tries to do it every night, which I don't like
I would advise you to install system qt and then do the following trick. Try:
which qmake
For me, this gives /usr/bin/qmake. I can then set QT_DIR environment variable to /usr and qmake will be found properly and used to build Paraview.
Martin is doing some hot-fixes in the ThirdParty package to improve things - have to say, he has done an amazing job and I'm happy we switched the way ThirdParty is done in the release. Please bear with us for a while until this gets fully automated; people already say it is much better than it used to be.
Hrv
Hrvoje Jasak
Providing commercial FOAM/OpenFOAM and CFD Consulting: http://wikki.co.uk
hjasak is offline   Reply With Quote
Old   December 4, 2010, 03:21
David Hora
david is on a distinguished road
Had the same problem. My solution was
export LD_LIBRARY_PATH=$LD_LIBRARY_PATH:/home/$USER/OpenFOAM/OpenFOAM-1.6-ext/ThirdParty/rpmBuild/BUILD/qt-everywhere-opensource-src-4.7.0/lib/
before starting the compilation of qt
David
david is offline   Reply With Quote
Old   December 4, 2010, 07:14
Martin Beaudoin
mbeaudoin will become famous soon enough
Which platform are you using for compiling QT?
Martin
David
mbeaudoin is offline   Reply With Quote
Old   December 5, 2010, 05:06
David Hora
Hi Martin
It's Ubuntu 10.04. Everything compiles and paraview runs fine but there seems to be a problem with the reader. I get the following error if I open a case:
david@freitag:~/OpenFOAM/david-1.6-ext/run/tutorials/incompressible/simpleFoam/pitzDaily$ paraFoam
created temporary 'pitzDaily.OpenFOAM'
ERROR: In /home/david/OpenFOAM/OpenFOAM-1.6-ext/ThirdParty/rpmBuild/BUILD/ParaView-3.8.1/Servers/Common/vtkProcessModule.cxx, line 1065
vtkProcessModule (0x19e6830): Object type: vtkPV3FoamReader, could not find requested method: "SetRefresh"
or the method was called with incorrect arguments.
while processing
Message 1 = Invoke
Argument 0 = id_value {114}
Argument 1 = string_value {SetRefresh}
Argument 2 = int32_value {0}
ERROR: In /home/david/OpenFOAM/OpenFOAM-1.6-ext/ThirdParty/rpmBuild/BUILD/ParaView-3.8.1/Servers/Common/vtkProcessModule.cxx, line 1066
vtkProcessModule (0x19e6830): Aborting execution for debugging purposes.
Aborted
setRefresh is present in vtkPV3FoamReader of 1.7.x but not in 1.6-ext or 1.6.x. After adding the function, paraview complains about the missing SetUseVTKPolyhedron.
Regards
David
Old   December 5, 2010, 11:09
Martin Beaudoin
Hello David,
Ubuntu 10.04 was one of my test OS while developing the new ThirdParty packaging. I am using the same pitzDaily test case for testing ParaView, and I did not notice such problem the last time I tried it.
> vtkProcessModule (0x19e6830): Object type: vtkPV3FoamReader, could not > find requested method: "SetRefresh"
I fail to understand your problem:
If the method "vtkPV3FoamReader::SetRefresh()" is not present in the source code of 1.6-ext, then how could the reader compiled for 1.6-ext ask for this method in the first place???
I would suggest that your 1.7.x and 1.6-ext installation are somehow mixed-up.
It seems to me you are loading the reader compiled for 1.7.x instead of the reader compiled for 1.6-ext.
Martin
Hi Martin
while processing
Message 1 = Invoke
Aborted
Regards
David
Old   December 6, 2010, 04:46
David Hora
I tried to recompile the comlete stuff in a clean environment to be sure that there is nothing that could be mixed-up. Unfortunately without success, same error message. I never had such problems before and I was suprised that I couldn't find anything in the forum about it. In the worst case I will have to do it the old way.
David
Old   December 6, 2010, 13:30
Pablo Caron
pcaron is on a distinguished road
which qmake
Hrv
Dear Hrvoje, I tried the QT_DIR trick. After I changed the QT_DIR it started compiling paraview but it failed installing.
Here is the last part of log file corresponding to AllMake
INFO: relinking /home/pablo/OpenFOAM/OpenFOAM-1.6-ext/ThirdParty/packages/ParaView-3.8.1/platforms/linux64GccDPOpt/lib/paraview-3.8/ooo3/share/uno_packages/cache/uno_packages/LRUgAW_/mysql-connector-ooo.oxt -> /usr/lib64/ooo3/share/extension/install/mysql-connector-ooo.oxt (was /usr/lib64/ooo3/share/extension/install/mysql-connector-ooo.oxt/)
ERROR: link target doesn't exist (neither in build root nor in installed system):
  /home/pablo/OpenFOAM/OpenFOAM-1.6-ext/ThirdParty/packages/ParaView-3.8.1/platforms/linux64GccDPOpt/lib/paraview-3.8/qt4/bin -> /home/pablo/OpenFOAM/OpenFOAM-1.6-ext/ThirdParty/packages/ParaView-3.8.1/platforms/linux64GccDPOpt/lib/bin
Add the package providing the target to neededforbuild and Requires
  /home/pablo/OpenFOAM/OpenFOAM-1.6-ext/ThirdParty/packages/ParaView-3.8.1/platforms/linux64GccDPOpt/lib/paraview-3.8/qt4/include -> /home/pablo/OpenFOAM/OpenFOAM-1.6-ext/ThirdParty/packages/ParaView-3.8.1/platforms/linux64GccDPOpt/lib/include
  /home/pablo/OpenFOAM/OpenFOAM-1.6-ext/ThirdParty/packages/ParaView-3.8.1/platforms/linux64GccDPOpt/lib/paraview-3.8/qt4/lib -> /home/pablo/OpenFOAM/OpenFOAM-1.6-ext/ThirdParty/packages/ParaView-3.8.1/platforms/linux64GccDPOpt/lib/lib64
  /home/pablo/OpenFOAM/OpenFOAM-1.6-ext/ThirdParty/packages/ParaView-3.8.1/platforms/linux64GccDPOpt/lib/paraview-3.8/qt3 -> /home/pablo/OpenFOAM/OpenFOAM-1.6-ext/ThirdParty/packages/ParaView-3.8.1/platforms/linux64GccDPOpt/lib/lib/qt3
error: Estado de salida erróneo de /home/pablo/OpenFOAM/OpenFOAM-1.6-ext/ThirdParty/rpmBuild/tmp/rpm-tmp.g7ZEbt (%install)
Errores de construcción RPM:
Installing package: ParaView-3.8.1
  Uninstalling ParaView-3.8.1 using RPM: ParaView-3.8.1-linux64GccDPOpt.x86_64
  Installing ParaView-3.8.1 using RPM file: /home/pablo/OpenFOAM/OpenFOAM-1.6-ext/ThirdParty/rpmBuild/RPMS/x86_64/ParaView-3.8.1-linux64GccDPOpt.x86_64.rpm
error: la apertura de /home/pablo/OpenFOAM/OpenFOAM-1.6-ext/ThirdParty/rpmBuild/RPMS/x86_64/ParaView-3.8.1-linux64GccDPOpt.x86_64.rpm falló: No existe el fichero o el directorio
Done installing package ParaView-3.8.1
Done ThirdParty AllMake: Stage4
Done ThirdParty Allwmake
The complete log exceed the posts maximum. Any ideas?
My system:
OpenSuse 11.2
system's qmake: 4.6.3
If you need more information don't hesitate to ask me.
Regards
Pablo
pcaron is offline   Reply With Quote
Old   December 6, 2010, 17:23
David Hora
Hi Martin
It succeeded with paraview-3.8.0 (and qt 4.6.3). Has it really been tested with 3.8.1? Not only the compilation, also the loading of a case?
Is there anyone else who tried to compile it on Ubuntu 10.04? Feedback would be nice.
Best regards
David
Old   December 7, 2010, 01:24
Martin Beaudoin
Yes it was tested on 5 different OSes, including Ubuntu 10.04 and OpenSuSE 11.3.
It was tested only with ParaView 3.8.1, and yes, cases were loaded and visualized using paraFoam.
None of the test platforms had any traces of OF 1.7.x source code.
Again, there is no way a source code compiled for 1.6-ext could ask for methods only present in 1.7.x source code.
Check your ThirdParty directory settings.
Check your paraview plugins directories.
Martin
Hi Martin
Best regards
David
Old   December 7, 2010, 02:31
L.Tuominen
tuominen is on a distinguished road
David
Try deleting $HOME/.config/Paraview directory. I think that helped in my machine.
Lasse
tuominen is offline   Reply With Quote
Old   December 7, 2010, 14:47
David Hora
Thank you very much, Lasse. That solved the problem
Best regards
David
Old   December 8, 2010, 09:52
David Boger
boger is on a distinguished road
Hi Pablo,
Have you solved your problem? If not, can you show the part of the log file where the first error occurs?
David A. Boger
boger is offline   Reply With Quote
Old   December 9, 2010, 07:09
Pablo Caron
Originally Posted by boger View Post
Hi Pablo,
Hi David,
Yes, I solved the problem, yesterday
I don't know what was wrong with system's QT. I uncommented the line corresponding to qt-every... in the script AllMake.stage4. So, I'm using qt-4.7.0 from the ThirdParty directory.
It's seems to be an issue (bug?) in the script. After I compile the Qt the Paraview step complains about missing QT_DIR definition. Reloading all variables (. ~/OpenFOAM/OpenFOAM-1.6-ext/etc/bashrc) again solved the problem.
Everything is working now!!
Thanks for your reply.
Regards
Pablo
Old   December 9, 2010, 13:49
aerothermal's Avatar
Guilherme da Silva
aerothermal is on a distinguished road
Send a message via Skype™ to aerothermal
Paraview errors:
Qt QTGUI library not found.
Qt QTSQL library not found.
Qt QTNETWORK library not found.
Qt QTCORE library not found.
CMake Error at VTK/GUISupport/Qt/CMakeLists.txt:123 (QT4_WRAP_CPP):
Unknown CMake command "QT4_WRAP_CPP".
Does someone knows how to fix that?
aerothermal is offline   Reply With Quote
Old   December 9, 2010, 13:58
Pablo Caron
Originally Posted by aerothermal View Post
Paraview errors:
Hi Guilherme, the information you're giving it's not enough to understand the problem.
Can you give us a little more information. What are you trying to do? Compile Paraview? Run Paraview?
Regards
Pablo
Old   December 9, 2010, 14:02
David Boger
Paraview errors:
What do you get for "which qmake" and "qmake --version"
David A. Boger
Old   December 9, 2010, 14:24
Default qmake
  #18
Guilherme da Silva
See the results of qmake queries
$which qmake
/usr/bin/qmake
$echo $QT_DIR
/usr
$ qmake --version
Qmake version: 1.07a (Qt 3.3.8b)
Qmake is free software from Trolltech ASA.
Old   December 9, 2010, 14:26
Guilherme da Silva
I am trying to compile the AllMake.stage4
I have Paraview from 1.7.1 and 1.5dev versions.
Do I need to compile it for 1.6ext?
Old   December 9, 2010, 14:40
David Boger
Sounds like your qt is pretty old. Can you update it? apt-get install qt?
David A. Boger
OpenFOAM 1.6 installation in Debian 5.06 lenny IA64 icingfish OpenFOAM Installation 8 October 8, 2010 02:42
OpenFOAM 1.6 installation in Ubuntu 9.1 jsm OpenFOAM Installation 4 January 3, 2010 22:53
Problem installing OpenFOAM 1.5 installation on RHEL 4. vwsj84 OpenFOAM Installation 4 April 23, 2009 04:48
64bitrhel5 OF installation instructions mirko OpenFOAM Installation 2 August 12, 2008 18:07
Adventure of fisrst openfoam installation on Ubuntu 710 jussi OpenFOAM Installation 0 April 24, 2008 14:25
