pipe
Old   December 2, 2010, 07:34
Default pipe
Fabio Malizia
Fabio88 is on a distinguished road
Hello
I've done a simulation of a turbulent pipe (Re_tau=200), I need now the value of the mean U...is there some post processing utilities for this? or also for calculate the u', v' (but also the only the Umean because I calculate the others with the filter calculator in paraview)
thank you all
Fabio88 is offline   Reply With Quote
Old   December 2, 2010, 08:21
Cedric Van Holsbeke
CedricVH is on a distinguished road
Calculate the magnitude of the velocity: foamCalc mag U
Average this magnitude at the inlet or outlet: patchAverage magU patchname
CedricVH is offline   Reply With Quote
Old   December 2, 2010, 11:20
Fabio Malizia
but this type of averaging give me the average value on all inlet (then an average in in the all section) or it is an average on streamwise direction?
because I need a mean value for obtain the fluctuations of velocity...(then I've to transform them from Cartesian coordinates to cylindric one but for this I use the filter calculator)
then I need or a temporal mean among the different time steps or a spatial mean in the streamwise direction...
thank you for the answer
Old   December 12, 2010, 04:32
Fabio Malizia
I found a solution....
I use the filter temporal statistics and I obtain the U average and after using append attributes I can merge the data of the simulation and the data of the temporal statistic and after calculate the fluctuations.
best regards
Fabio
pipe in pipe heat exchanger JohannV FLUENT 3 December 3, 2009 02:53
CYCLIC BC in pipe flows matthias OpenFOAM 0 November 5, 2009 10:52
flow in perforated pipe distributor pertupd ANSYS 0 August 12, 2009 08:36
My Revised "Time Vs Energy" Article For Review Abhi Main CFD Forum 2 July 9, 2002 09:08
Terrible Mistake In Fluid Dynamics History Abhi Main CFD Forum 12 July 8, 2002 09:11
