December 2, 2010, 07:34 |
pipe
Fabio Malizia
Hello
I've done a simulation of a turbulent pipe (Re_tau=200), I need now the value of the mean U...is there some post processing utilities for this? or also for calculate the u', v' (but also the only the Umean because I calculate the others with the filter calculator in paraview) thank you all |
December 2, 2010, 08:21 |
Cedric Van Holsbeke
Calculate the magnitude of the velocity: foamCalc mag U
Average this magnitude at the inlet or outlet: patchAverage magU patchname |
December 2, 2010, 11:20 |
#3 | |
Fabio Malizia
because I need a mean value for obtain the fluctuations of velocity...(then I've to transform them from Cartesian coordinates to cylindric one but for this I use the filter calculator) then I need or a temporal mean among the different time steps or a spatial mean in the streamwise direction... thank you for the answer |
December 12, 2010, 04:32 |
Fabio Malizia
I found a solution....
I use the filter temporal statistics and I obtain the U average and after using append attributes I can merge the data of the simulation and the data of the temporal statistic and after calculate the fluctuations. best regards Fabio |
pipe in pipe heat exchanger | JohannV | FLUENT | 3 | December 3, 2009 02:53 |
CYCLIC BC in pipe flows | matthias | OpenFOAM | 0 | November 5, 2009 10:52 |
flow in perforated pipe distributor | pertupd | ANSYS | 0 | August 12, 2009 08:36 |
My Revised "Time Vs Energy" Article For Review | Abhi | Main CFD Forum | 2 | July 9, 2002 09:08 |
