Particles don't stick to the wall with stick BC
Old   December 8, 2010, 03:04
Default Particles don't stick to the wall with stick BC
Paul Reichl
preichl is on a distinguished road
Hi All,
I am running a case using icoLagrangianFoam (in OF 1.6-ext) and I am finding that although the particles reach the wall and stop at a particle radius away, they are not stuck to the wall (and can be blown off if the local flow field is sufficiently strong).
I have the wall interaction set as follows:
StandardWallInteractionCoeffs
type stick;
This issue seems very similar to the post at
http://www.cfd-online.com/Forums/ope...ting-wall.html
which suggests that a solution to this has been implemented.
Should I be seeing this in OF 1.6-ext? (i.e. should the fix mentioned in the link above be in OF-1.6-ext) and if not, does anyone know what I can try to fix this?.
I also have OF 1.7.x installed, although my first attempt at compiling icoLagrangianFoam in 1.7.x complained about missing header files. Has anyone got icoLagrangianFoam working in 1.7.x?. I am guessing that the fix in the link above is in 1.7.x.
Any help or pointers to what I should try would be most appreciated. (i.e. can I take some of the code from 1.7.x and add it to 1.6-ext to implement the fix, or should I try and get icoLagrangianFoam working in 1.7.x).
Thanks in advance,
Paul.
preichl is offline   Reply With Quote
Old   December 8, 2010, 19:06
Paul Reichl
Setting the wall boundary condition to escape is good enough for what I need at the moment.
Old   December 13, 2010, 09:06
Cedric Van Holsbeke
CedricVH is on a distinguished road
This is still not fixed in OpenFOAM 1.7.x. I have submitted a bug report.
CedricVH is offline   Reply With Quote
Find a particle's distance to a wall gruber OpenFOAM 9 February 15, 2012 06:22
Errors running allwmake in OpenFOAM141dev with WM_COMPILE_OPTION%3ddebug unoder OpenFOAM Installation 11 January 30, 2008 20:30
Wall functions? Pr Main CFD Forum 7 April 8, 2004 06:15
Quick Question - Wall Function D.Tandra Main CFD Forum 2 March 16, 2004 04:29
Wall functions Abhijit Tilak Main CFD Forum 6 February 5, 1999 01:16
