Rep Power: 17 ![]() |
Hi everybody.
Sorry for my ignorance in linux and programming. I installed OpenFOAM-1.5-dev from CAE Team PPA (I followed openfoamwiki instructions) and now I'm trying to run this MRFSimpleFoam tutorial. If I run the case with MRFSimpleFoam I obtain the message: Code:
MRFSimpleFoam: command not found |
Travis Carrigan
Rep Power: 15 ![]() |
Both MRFSimpleFoam and simpleSRFFoam have to be built from source. I don't know why this is, but it's pretty easy.
- Navigate to the tutorials directory - Find MRFSimpleFoam - The source is inside the MRFSimpleFoam tutorial directory - Run wmake, and you're done! - Do the same for simpleSRFFoam |
thanks for your explanations, tcarrigan.
I looked for the folder and I found /usr/share/doc/openfoam-dev-1.5/examples/MRFSimpleFoam/MRFSimpleFoam. It contains a subdirectory Make (with files and options files) and two files: MRFSimpleFoam.C and createFields.H. I tried wmake but it fails (not found). Maybe I have to run make? I use Ubuntu 10.04 64-bit. [I move this thread to Installation section, you defined my problem] |
MRFSimpleFoam Tutorial | bastil | OpenFOAM Running, Solving & CFD | 48 | August 1, 2012 10:00 |
How to add correcting pressure equation in SIMPLE of MRFSimpleFOAM? | renyun0511 | OpenFOAM Programming & Development | 0 | November 4, 2010 01:38 |
Compared MRFSimpleFoam and Fluent in a centrifugal pump! | renyun0511 | OpenFOAM Running, Solving & CFD | 8 | July 6, 2010 06:24 |
Compared MRFSimpleFoam and Fluent in a centrifugal pump! | renyun0511 | OpenFOAM Running, Solving & CFD | 2 | December 12, 2009 21:58 |
Testing of OpenFOAM 1.5beta Commenced | OpenFOAM discussion board administrator | OpenFOAM Announcements from ESI-OpenCFD | 0 | May 19, 2008 05:22 |
